Overfilled Engine Oil ?!?!
Old Apr 15, 2010 | 06:13 PM
scmaxima's Avatar
I just changed my oil to Castrol GTX, but because i burn a little bit of oil so i told the guy to fill in a bit more than the 4.25 quarts.
After it was completely drained he put about 4.75 quarts...
Now the engine is sounding really weird, when ever at idle at any gear except N, the car like bogs? it drops like a 100 RPMs then goes back up, drops and goes back up, i kinda feel like the car is gonna die but it doesnt ...
When i lift the hood it sounds like there is knocking or something, but its not knocking.. idk..
Is this common because the new oil change or whats the problem? =/
Old Apr 15, 2010 | 06:28 PM
scmaxima's Avatar
anyone ? im really concerned
Old Apr 15, 2010 | 06:42 PM
importcf's Avatar
i really wouldnt think that would make that much of a difference
Old Apr 15, 2010 | 06:46 PM
Trini Boom's Avatar
It shouldn't make any difference because I use Castrol GTX high Mileage and the guy puts in the same amount as you stated and I never had problems. Your bogging is not oil changr related so you can rule that out.
Old Apr 15, 2010 | 06:47 PM
scmaxima's Avatar
then whats the reason for this problem??
it never happened till i changed the oil =/
went from mobil 1fully synthetic to castrol gtx but i dont think thats the reason
Old Apr 15, 2010 | 07:06 PM
scmaxima's Avatar
come on people.. it feels very bad driving it.. any cure or just let it wait till 2mm?
Old Apr 15, 2010 | 07:19 PM
WhiteMaxima9600's Avatar
Adding 1/4 of a quart of motor oil over would have not made your engine run any different. You must check other components, also if your that worried about the extra oil, just loosen the drain plug underneath and let a little run out.
Is your cel on?? (check engine light)
Old Apr 15, 2010 | 08:00 PM
scmaxima's Avatar
yea its on but for a bank 2 oxygen sensor and an egr valve thats it...
i drove my car again now after leaving it for an hour and it drive pretty good for like half an hour then the thing came back, it was less tho
u guys think it'll go away by itself?
Old Apr 15, 2010 | 08:21 PM
eFLO's Avatar
dude a 1/4 quart of extra oil will not cause what you are describing. there is an underlying issue here♦
Old Apr 15, 2010 | 08:23 PM
Snypa's Avatar
to set your mind at ease, Re-do the oil change and put the required amnt. I too dont think this should have caused this mch of a problem....cud it be your mind playing tricks or these is something else wrong with the car.?
Old Apr 15, 2010 | 08:40 PM
FallenOne's Avatar
you just did a waterpump, no? was the tensioner okay/replaced/touched?
Old Apr 15, 2010 | 08:58 PM
scmaxima's Avatar
ohh no.. the water pump and tstat are both here for like 2 days now i should be doing it 2mm afternoon..
do you think the problem is because of the waterpump and/or tstat?
Old Apr 16, 2010 | 01:01 AM
Leo_Koneval's Avatar
Whenever I do an oil change I usually use an entire jug with is 5 quarts (More or less) and nothing has ever happened. It think as long as you are not 2 or 3 quarts over the recommended amount you should be fine.
Old Apr 16, 2010 | 02:46 AM
ColombianMax's Avatar
sounds to me like you need your spark plugs torqued to spec
Old Apr 16, 2010 | 03:33 AM
Trini Boom's Avatar
Sounds to me that you should do what your check engine light tells you to do and change the O2 sensor and EGR Valve. More than likely, it is cloggged up with carbon which is in turn giving you pinging.
Old Apr 16, 2010 | 04:04 AM
Afterlife's Avatar
EGR= possible pinging.... try and get it cleaned or just delete it....much easier if your in there.
02 sensor= can make you run rich or lean depending on the fault,can also cause pinging if your running too lean.Airflow meter could be sending the wrong signals because of the 02 readouts.
too much oil will make a noticable vibration when accelerating 1/4 quart will not effect that i would look to other problems as far as the way it's running.
If it is sporatic try moving the wiring harness around the passenger strut while it's running and see if anything changes.
Hope that helps abit...
Old Apr 16, 2010 | 05:26 AM
1997MAXZ's Avatar
no chance the little extra oil would hurt the car
Old Apr 16, 2010 | 06:18 AM
cashoit's Avatar
yeah, im pretty sure my mech put like 5 qts in mine. no prob
Old Apr 16, 2010 | 07:04 PM
scmaxima's Avatar
oh ok..
so whats the problem then..
and ohh. when you change the waterpump do u need to replace the oil?!?!?
Old Apr 16, 2010 | 07:12 PM
HandsonMaxima.'s Avatar
isent the water pump behind the timing belt cover? so..there should be no oil in the engine to do that.
Old Apr 16, 2010 | 07:26 PM
95maxse3000's Avatar
i agree. deff clean or replace the egr valve and put in a new o2 sensor. as far as being doggy and pinging it also could be the ks (knock sensor) witch retards your timing 5 to 8 degrees causing doggyness and loss fuel milage
Old Apr 16, 2010 | 07:35 PM
scmaxima's Avatar
oh snap. ok ill clean the EGR Asap then..
Old Apr 16, 2010 | 07:38 PM
scmaxima's Avatar
****! i just changed the oil yesterday -__-
can i like tell the mechanic to keep this oil in a container or something to reuse it? it has less than 10 miles... fml
Old Apr 17, 2010 | 12:19 AM
Celired's Avatar
I do my own changes and I pour all 5 qts. into my car. Even if you did have a lot of extra oil it would just burn up.
Old Apr 17, 2010 | 01:17 AM
Seximus Maximus's Avatar
Normally that extra .5 quarts added makes it so the oil light doesnt come on/flicker when u start the car. I always add that little bit extra
Old Apr 17, 2010 | 05:45 PM
Do you have blue smoke coming out your tail pipe and ticking from the engine by any chance?
Old Apr 17, 2010 | 07:07 PM
scmaxima's Avatar
no not really.. i just changed the waterpump/tstat and even oil to find out that 3 fins from the pump fell in the oil 0.o so yea everything is good now except this annoying thing..
the problem happens mostly when im idling only on D or R the car just drops a 100 rpms or so then gets back up and the cycle continues, but it goes away easily. any method to end it permanently?
Old Apr 18, 2010 | 12:35 AM
test/clean your IACV yet? besides that, not much without some effort
Old Apr 18, 2010 | 09:19 AM
Trini Boom's Avatar
Hold on now. Three fins from the water pump broke off and fell into the cooling system? Is this the OEM pump you are changing for the first time? Wow thats crazy so that means those fins were trapped by the T-stat and got it out when you replaced or it slipped past and went into the radiator?
Old Apr 18, 2010 | 11:02 AM
EsQueue's Avatar
What about the check engine light? O2 sensors play a big part on how the engine runs. When my egr tube was clogged I got a code that just displayed the light and another egr code that would throw the car into limp mode.
Old Apr 18, 2010 | 12:58 PM
Snypa's Avatar
i guess you could. It should still be slightly golden....hopefully.
Old Apr 18, 2010 | 01:17 PM
scmaxima's Avatar
ok so to answer all the questions..
yes i did change the new oil lol it had less than like 20 miles but its ok.
so yea the 3 fins did fall into either my cooling system or my oil system one of the 2 idk which one because while i wasnt looking the guy said oh those 3 fins just dropped ... and yup the pump itself had 3 broken ones 0.o now the new oem one works flawlessly. The car runs very very good now. knock on wood. Idling is VERY smooth and soo quiet unlike before. When i WOT it sounds loud and flawless unlike before no cracking sounds!
another note... my brakes used to suck *****... the brake system and powersteering fluid were a bit low so after he filled them up. now steering is a hell of a lot better, and my braking doesnt make squeeking noises at all unlike before (it was horrible, everyone would look at my car with that WTF look) , and steering is a lottt smoother too lol
Sorry for writing all this but my car is definitely a whole lot better! There are no sounds inside the car except one thing.. the front suspension. idk whats the problem, but on every bump or hole in the street its very rough and makes a popping sound when i turn
the old owner put on KYB AGX's and some yellow springs.. so does anyone have a solution to fixing this?
im really happy now tho
Old Apr 18, 2010 | 03:36 PM
the popping sound could be a cv shaft going to sh*t. it also could be a bad ball joint. does it do it when your sitting still and turning the wheel or when you hit a bump?
Old Apr 18, 2010 | 05:27 PM
scmaxima's Avatar
lol both..
when im on a flat place and make a turn you can hear the poping sound, and when i hit the bump its another popping sounds , sometimes both sounds come at the same time lol
oh and im telling you . the car is EXTREMELY stiff on bumps, but handling at fast speeds is pretty damn good =/
Old Apr 19, 2010 | 09:34 AM
Celired's Avatar
I remember once I overfilled my engine with like 8 qts, what a doozey that was, I quickly learned that wasn't a good idea.
Old Apr 19, 2010 | 10:01 AM
lol both..
probably just a bad ball joint
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
ag90fox
Sep 9, 2015 12:22 PM
