power window electrical issue
Old Aug 27, 2010 | 08:29 AM
musictech55's Avatar
so i drive a 95 se, and the only power window that works is the driver one, my first thought was that the window lock was stuck so i switched out the control panel, still nothing. there is power going to the other windows and when i connect the driver control panel to the passenger side i can then roll down the passenger window with the driver button. what is causing this?
Old Aug 27, 2010 | 10:31 AM
ajm8127's Avatar
So you are saying that when you changed the window switch, it worked. Correct?
Old Aug 27, 2010 | 11:24 AM
Nopike's Avatar
I still think you have an issue with the lock signal. Switch, wiring or the drivers door module that the signal goes to.
Check out the FSM in the EL section.
On-board Diagnosis — Mode IV (Power window
monitor) HOW TO PERFORM MODE IV
If I read it correctly the mode will lower the diver window and stop it when lock is depressed.
Old Aug 27, 2010 | 11:30 AM
cashoit's Avatar
wait a min man...if u swapped out the passenger panel for teh driver panel, and then it worked. Doesnt that mean that the passenfer panel is blown?
http://www.courtesyparts.com brotha. get a new one.
noobs
Old Aug 27, 2010 | 03:49 PM
noobs
no cause i can only control the window i connect it to with the driver switch
Old Aug 27, 2010 | 08:27 PM
najee1062's Avatar
Then you're having a window lock issue.
Old Aug 29, 2010 | 05:58 PM
does anyone have diagrams of the wiring for that harness?
Old Aug 29, 2010 | 06:48 PM
Nopike's Avatar
They are in the FSM, do a search.
Old Aug 29, 2010 | 07:17 PM
DennisMik's Avatar
you can download a FSM frome here:
http://www.nicoclub.com/FSM/maxima/
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
The Frye
Feb 3, 2019 08:34 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
