non-bose removal with pics
Old 08-27-2010 | 09:32 PM
asand1's Avatar
I didn't see a good write for this, so I thought I'd make one. I will quote some othe members here, so thank you for your contributions, and I hope you don't mind. First off heres a quick run through.
Originally Posted by komik
- Remove trim panel around shifter
- Unplug cigarette lighter if necessary
- Remove one screw and pull ashtray out, set aside
- Pull bottom of trim piece holding hazard / defog buttons and upper vents (pops out). The directions I read said to remove it completely, mine comes out enough at the bottom to reach the screws behind it.
- Remove four screws (two top, two bottom) to release CC & radio assembly.
- Pull assembly away from dash.
- Unplug all wiring harnesses / antenna wires.
- Flip assembly over and remove four screws holding the trim panel to the metal bracket.
- Remove screws on each side of radio (mine only had two, but it had been removed before, so there may be more) holding radio to bracket.
- Pull radio out through front of bracket.
My Original Stereo with worn buttons and dead LCD
Grasp the shifter bezel by the lower inside corners and pull firmly.
Remove screw (red arrow). now reach behind from under neath and pull hard.
Originally Posted by cashoit
Remove the screw then jus pull it out with all ur strenght. U wont break it. There is a nissan superman clip on it that is a pain to get out. Jus pull really hard.
Backside of astray with "superman" clips.
Pry with a plastic tool directly under each button and lift up. This will allow enough room to access the two screws. Break them loose with an 8mm 1/4 drive socket on looong extension and remove.
Now remove lower 8mm screws same way as top. Pull out unit and disconnect all wires.
Turn unit over and remove 4 screws from plastic bezel and remove bezel.
Remove 4 tapered Philips screws attaching brackets to stereo. Slide stereo out through the front.
Finished
other random photos
Rear view of '96 non-Bose (Clarion)
Tools required.
Old 08-27-2010 | 09:55 PM
j-dawg's Avatar
Dang that seems kinda nice to be able to just take out those screws and slide the head unit out. For the Bose unit the screws are on the sides of those two big metal brackets that also hold the hvac controls and cubby; you gotta take the whole panel out to get at just the stereo, which can be a huge PITA if you're trying to troubleshoot something.
Old 08-27-2010 | 09:57 PM
5150pa's Avatar
I've been looking for something just like this, Thanks man!
I've seen a few guides around on the internet but you had to pay for them... No thanks.
Old 08-27-2010 | 10:16 PM
asand1's Avatar
You do have to remove the whole unit and unscrew the 4 tapered philips from the side of the stereo. I just Photographed #7 as an after thought to illustrate where the bezel attaches to the brackets.
Old 08-28-2010 | 05:38 AM
Trini Boom's Avatar
Originally Posted by asand1
Turn unit over and remove 4 screws from plastic bezel (holes marked here). Remove bezel, and 4 tapered Philips screws attaching brackets to stereo. Slide stereo out through the front.
I don't recall having to do this to get the stereo out. Once you remove the screws at the side that's holding the head unit, it will slide right out without removing bezel.
Old 08-28-2010 | 05:58 AM
96i30azn's Avatar
carstereohelp.com used to have free instructions. i guess they gayed out
Old 08-28-2010 | 07:14 PM
ivorton23's Avatar
yeesssss....u da man...thanks for posting this thread man...this should be in the stickies.
Old 08-30-2010 | 06:15 PM
asand1's Avatar
updated
updated, bump
James92SE
142
01-02-2024 09:23 AM
06-06-2017 02:01 PM
Noela
09-26-2015 08:22 AM
newtomaxima
09-25-2015 05:16 AM
worldwiderecognized
09-24-2015 06:56 PM
Quick Reply: non-bose removal with pics
