Evap Control System - Code
Old Oct 10, 2010 | 09:06 PM
RustyMax's Avatar
Hey guys now before you go blowing up this thread saying "read the stickies" let me just say I did and from what I read it's something akin to a "jackpot" code. My question is has anyone any personal experience with their max showing code #0705 "Evap Control System"? Like has anyone got this code and had success fixing it and what you did. Any tips are appreciated thanks!
Old Oct 10, 2010 | 09:09 PM
2000_MAXIMA_KING's Avatar
Interested I have the P1447 code and its also a "jackpot" code, 97 max btw.
Old Oct 10, 2010 | 09:50 PM
RustyMax's Avatar
Yeah mine is a 98, you'd think Nissan would have a particular code for each component in the event one went out, not just a crazy single code that covers one or more of over 20 different possible solutions. Makes you think they'd want you in the dealer replacing countless parts before finding the solution. *stare*
Old Oct 11, 2010 | 03:22 AM
DennisMik's Avatar
My car was throwing both the P1445 and P1447 codes, but not together. I would get the one code, reset my ecu and then get the other, but not alternating, either.
My problem turned out to be the charcoal filled EVAP canister located behind the driver's rear wheel. It was leaking its charcoal and the stuff was being sucked into the engine.
What I had discovered was that when I took the EVAP canister purge control valve and/or the EVAP canister purge volume control valve off the car, little black granules came out of them. I then found a service bulletin about this (NTB00-085a) and when I tested the EVAP canister, it was bad.
Old Oct 11, 2010 | 09:49 AM
oVeRdOsE's Avatar
I have those code since a year now.
I tried almost everything on what I found with the ''search''.
( clean the canister valve and the volume control valve, I tested all the component with a 12v battery, everything seems alright. I shoot air in the system)
And still have those code :
p0440 : exhaust gas recirculation malfunction
p0441 : evaporative emission system flow during non-purge
p0443 : evap purge solenoide valve 1 control ckt
p0447 : ??
I guess those codes keep nissan alive!
Old Oct 11, 2010 | 10:02 AM
Yea I found the tsb on how to clean the system, search for it and try it. Ill report back when I perform the procedure whenever I can get around to it.
Old Oct 11, 2010 | 02:42 PM
cartman854's Avatar
I got those codes after my VI swap, found out I forgot to plug the purple sensor in on top of the UIM, incase thats the same with you.
Old Oct 12, 2010 | 11:10 AM
Swazey's Avatar
im dealing with 0807 and 0111. car smells of gas fumes. replacing vacuum lines first
Old Oct 15, 2010 | 07:58 AM
99zx2's Avatar
0705 is a small leak code. check your gas cap!
Old Oct 15, 2010 | 09:23 AM
RustyMax's Avatar
Really now? When I looked it up on the stickies here it just gave me the generic evap sys answer, where did u find this out?
Old Oct 15, 2010 | 11:24 AM
99zx2's Avatar
see here: http://forums.maxima.org/4th-generat...ode-fixed.html
BkGreen97
Apr 2, 2016 05:47 AM
Starrider
Dec 18, 2015 04:43 AM
220k+ A32
Sep 11, 2015 02:18 AM
carid
Sep 9, 2015 05:06 AM
dcam0326
Sep 7, 2015 07:26 AM
