fog lights
fog lights
hello i have a question my max 1995 5 speed didnt come with fog lights. while i was at the junk yard today i came across a 96 max with fog lights. i took the fog light, housing, and mounting brackets and the headlight switch with the fog light switch all for 20 bucks. i have searched my question is where do they wire up where do i tap in for wiring from searching im under the impression all the wiring is there i also know i have to cut my bumper any input or help is appreciated
hello i have a question my max 1995 5 speed didnt come with fog light while i was at the junk yard today i came across a 96 max with fog lights i took the fog light housing and mountin brackets and the headlight switch with the fog light switch all for 20 bucks. i have searched my question is where do they wire up where do i tap in for wiring from searching im under the impression all the wiring is there i also know i have to cut my bumper any input or help is apreciated
From what other .org members told me, if your GXE has power seats, your fog light wires should already be there taped up to the support under the bumper. If it is there, you just need to cut out the hole in the bumper, replace the signal stalk with the one with the fog light and the relay/fuse and that should be it. Unfurtunately, my GXE has no power seats which I don't have the wiring.
Chassis harness has the foglight wiring on all the cars I've seen.....Just in case a customer wanted them installed by the dealer! You need to remove you wheel well splash shields and the harness should be setting on the frame rails.....If you find yourself having to make a harness you'll only need to run 1 wire to each lamp assy from a relay( 12-14 gauge wiring) and a short ground wire to the frame.....
trini i dont have power seats but i just looked and the wires and connector are there
Hmm, interesting... I couldn't find mine but if you could, can you post a pic of the location and the connector so that I can double check my car again. After someone on the org told me that info and I couldn't find mine, I told myself that I couldn't get fogs.
i wll when i get off work
to the left of that hole taped to the side of the support if u have a splash guard take it iff u will see the wires taoed the have a connector on them same for the other side
The Frye
09-02-2021 11:03 AM
fastcarny
10-06-2015 10:42 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
