car won't start ?
car won't start ?
hi i have 96 maxima gxe with 170,000 miles and this morning tried to start the car and it cranks but it won't start what is the first thing i have to check is there a way to check if its the fuel pump or the timing belt ?
I doubt it's the timing chain but here are the codes:
Code: P0443 | Description: EVAP Canister Purge Control Valve/Solenoid Valve
Code: P1105 | Description: Manifold Absolute Pressure Switch
Code: P0325 | Description: Knock Sensor
The knock sensor isn't preventing your car from starting..
well this is what i did i step on the gas a few times when trying to turn the key on and i step on the gas all the way in and then turn the key on and it started and i acelerate a couple of times and thats it it been working good since yesterday does someone knows what happend or what should i change so this won't happend again ?
well today the maxima started to cut out when i was at a red light and the RPS started to go up and down then it goes normal again does somebody knows what it is. im thinking the fuel pump does someone knows how to check the fuel pressure ?
replace the fuel presure regulator
ok i took the car to the autozone and they pull the codes and it came out to be a 1302,0201,0807, and 0304 i check the first 3 and all of them it says its a camshaft position sensor and the 0304 its the knock sensor but which one is the one that it's making the car cut off some times and also i heard a whisile noise on the vacum lines but i can't find which one is the one making the noise . please any help would be apreciated.
Dude, people aren't responding to your post because you are not listing out the codes for us to tell you. The codes are in the stickys with the numbers and their respective descriptions. When you get that done, we will tell you which one is causing it to happen.
0201
Diagnostic Trouble Code 0201 indicates a problem with the ignition coil and power transistor
The items to check include
- Harness or connectors (the ignition primary circuit is open or shorted.)
- Power transistor unit built into ignition coil
- Condenser
- Crankshaft Position Sensor (REF)
- Crankshaft Position Sensor (REF) circuit
1302
MAP/BARO SW Solenoid/Valve
807
The Evaporative Emission (EVAP) Canister Purge Volume Control Solenoid Valve uses an on/off duty cycle to control the flow of fuel vapor from the EVAP canister. Diagnostic Trouble Code 1008 is set when the Engine Control Module (the computer) detects an improper signal through the valve. The problem is likely to be in the electrical wiring, harness, or the valve itself.
well here they are i still don't know what is the sensor that is doing my check engine light blink
- Condenser
1302
807
0201
- Condenser
1302
807
- Condenser
1302
807
i took the maxima to the autozone and they plug the machine and im still getting the same codes p0443 that means the 0807 p1105 that means 1302 and p0235 thats 0304 and this is the knock sensor . no other codes indicating a misfire, i wonder if it has something to do when i tried to read the codes myself from the ECU and i let the screw in a bad position but i check and its ok .
ok so i tried to reset the screw and still the same blinking light also now my windows don't work and my door lock doesn't work and the seat buttons don't work so i check the fuses from the underhood and they are all fine and theones on the inside are all ok so what else could it be ?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
