trunk remote
Old Jan 17, 2011 | 11:38 AM
kel456's Avatar
trunk remote
I am interested in trunk remote. Since I have a lever instead of push button for the trunk, I think I need a solenoid plus relay for the trunk in order to do a trunk remote. The question is if I can go to the junkyard to get an OEM trunk solenoid, if that is do able. Or is this not worth the trouble like the automatic temperature. And I guess I need to install a push button switch to open the trunk from the cabinet. Thanks for the help.
Old Jan 17, 2011 | 11:48 AM
tigersharkdude's Avatar
My keyless remote has a trunk button
Old Jan 17, 2011 | 11:57 AM
kel456's Avatar
I should have included more info. I have an aftermarket RS alarm with aux channels. I am thinking about remote trunk but mine trunk is manual pull release.
Old Jan 17, 2011 | 12:30 PM
99greddymax's Avatar
my brother had a no options gxe.. when he had his viper responder installed, he added an aftermarket pull type solenoid added to the factory cable. Worked like a charm.
luke95gxe's Avatar
things you will need is a door panel with the push button trunk pop and a relay and solenoid shouldnt be hard i have been thinking about this myself all the wiring is there
Old Jan 17, 2011 | 01:02 PM
kel456's Avatar
It sounds like a mod direction. I am curious how much work it is going to be. Most importantly how the solenoid is installed if it is not OEM. Does it require more parts and etc. I have done some searching and still doing searches. Anyone has more info on this would greatly be appreciated. Please only related to Max 4th gen b/c of the solenoid arrangement, alignment, location and additional parts for 4th gen trunk. Thanks.
Old Jan 17, 2011 | 01:30 PM
kashmiriomar's Avatar
i have a 99 maxima se without leather or bose and the keyless remote Does have the option for trunk.. can that be modded?
Old Jan 17, 2011 | 02:27 PM
kel456's Avatar
If yours is not a manual release then you can tap the purple/yellow in the kick plate. With an aftermarket alarm, use an aux if you don't have a dedicated trunk remote button.
Old Jan 17, 2011 | 06:13 PM
luke95gxe's Avatar
they made them stock with a trunk release so i think all u need is the parts from one that has that option and swap them over an program the remote u could prolly get all the parts from the junk yard
Old Jan 22, 2011 | 04:16 PM
luke95gxe's Avatar
i did mine today heres the write up
http://forums.maxima.org/4th-generat...-few-pics.html
REDinLV
Aug 15, 2024 12:30 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
flu2000
Sep 14, 2015 12:34 PM
rbaker100
Sep 6, 2015 02:46 PM
intimidator
Sep 5, 2015 07:23 PM
