front end noise
Old Mar 7, 2011 | 07:58 PM
1992maximase30's Avatar
front end noise
This is on a 99 infiniti i30, 113k miles.
While driving between speeds of 20-70mph, there's like a slight growling noise...from the driver side it sound like.
As the speed increases so does the pitch of the noise.
Turning left or right doesn't change in sound either, neither does different road conditions.
And this happened all of a sudden...any idea's?
Old Mar 7, 2011 | 08:28 PM
Maximeltman's Avatar
growling, or grinding? if it starts to sound that way when u hit 20mph, then it's something that rotates...
Old Mar 7, 2011 | 08:55 PM
Kico's Avatar
I have a lot of Idea's but you need to be more specific. Is the noise coming from the wheel on the drivers side? or Do you do you think it's coming from the trans on drivers side? Jack up the drivers side spin wheel and check for wheel barring play by shaking the wheel up and down that would be a start. Take the wheel off and inspect the caliper make sure It's in good working order and not hung up. Inspect the axle well your down there grab the axle close to block of the trans and check for play in the barring by doing the same thing you did to the wheel. Look at the axle seals check for leaks and check trans fluid. Good luck on finding the problem this should give you a start.
Old Mar 7, 2011 | 09:36 PM
darrick's Avatar
Dallas Nissan Enthusiast
wheel bearing
Old Mar 8, 2011 | 05:41 AM
gen4maxrehab's Avatar
i agree with darrick sounds like bad wheel bearings, jack it up spin it and try to replicate the sound
Old Mar 8, 2011 | 01:39 PM
thanks. i can't pinpoint the sound.
it it coming from the driver side.
like i said 20mph and up you hear the noise.
the faster you go the higher the pitch.
and when your turning left or right the noise doesn't fade or get louder and this happened all of a sudden.
and i can add to this.
the car sat in the garage for 2 years.
and i don't think they started it up till recently when they decided to sell it.
and it has 17 inch wheels. nothing too heavy (they're enkei's if that helps)
Old Mar 8, 2011 | 02:30 PM
asand1's Avatar
[quote=1992maximase30;7962144]the car sat in the garage for 2 years.
and i don't think they started it up till recently when they decided to sell it.quote]
Rusty rotor(s). Resurface and pads. My best guess. Also could be bearings, but it would be worse on a right turn.
Old Mar 8, 2011 | 02:42 PM
i noticed no change in sound when turning...well it does'nt start till about 20mph, so imagine how crazy i would look taking turns @ 25+ mph.
on the highway i tried to move the steering wheel back and forth...that didn't work.
Old Mar 9, 2011 | 07:44 AM
well. last night i jacked the car up.
the axle was tight and you could spin the wheel barely but i somewhat heard the noise.
this morning it was even worse.
i'm just gonna replace the bearing.
HOKUSMAX
Nov 13, 2017 04:34 AM
boomerbrian
Nov 8, 2015 05:10 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Justin Kroll
Sep 2, 2015 11:06 AM
official_style
Aug 29, 2015 10:10 AM
