idles high and wont pass 2000 rpm
Old Mar 16, 2011 | 06:05 PM
fignewtin88's Avatar
did a trans swap lately and now at idle it stays around 11-1200 rpm
while driving it just stops at like 1900-2200rpm cant figure it out changed maf 3 times
Old Mar 16, 2011 | 06:49 PM
VQ'rInWLA's Avatar
Trans swap? Auto to manual?
Old Mar 16, 2011 | 07:22 PM
Manual I blew up my last 5 speed a few mOnths ago
Old Mar 16, 2011 | 10:39 PM
Product_Of_Korea's Avatar
Is the throttle cable getting stuck some how??
Old Mar 16, 2011 | 11:32 PM
aackshun's Avatar
Got any codes? Check your crank shaft pos sensor
Old Mar 17, 2011 | 05:20 AM
I already checked crank sensor it's good checked my maf sensor it's good even swapped it with 3 others and still no change .. Sometime the car will run fine I can drive it normal but usually it just keeps giving me that problem
Old Mar 17, 2011 | 05:21 AM
Gonna check the codes today
Old Mar 17, 2011 | 09:17 AM
VQ'rInWLA's Avatar
Oh I missed the "wont pass 2000 rpm" part so that rules out an auto ecu being the case (which is why i was asking if you went from auto to manual). When it hits 2000 rpm, does it bounce off it like its hitting the limiter?
Old Mar 17, 2011 | 11:25 PM
No doesn't just feels like it cuts out fuel until rpm comes back unber 2k ... Also checked the codes today four codes came up I don't have the exact numbers with me but i remember it was
Iacv
O2 sensors bank one no activity
Map sensor
Nox sensor
I will double check tommrow and I already replaced the iacv and plan on replacing tb and all vaccum lines tommrow see if that helps
Old Mar 17, 2011 | 11:35 PM
FallenOne's Avatar
Iacv
Map sensor
Nox sensor
Hose?>O2>MAP>MAF>WIRE>ECU
In that order..
Old Mar 24, 2011 | 07:40 PM
After all this work I found the problem bad tps car runs fine now
Mar 12, 2020 12:06 AM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 11, 2015 05:29 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
