MAF Question
Old Mar 28, 2011 | 04:08 PM
Maximaum Driver's Avatar
MAF Question
I am working on a friend's 1999 Maxima. Currently I told her to go out and get me some CRC MAF cleaner, but I have question regarding the MAF.
Her car runs rough, or feels like it's missing at times. This can be at idle, or around 2500-3000 RPM when she took me for a drive. I could feel hesitations/missing/light bucking.
I had her start the engine, and I disconnected the MAF. I expected the engine to run smoother, if it was an MAF problem, but instead the engine just died. I plug it in and it fires right up again.
Any ideas?
Old Mar 28, 2011 | 05:25 PM
luke95gxe's Avatar
Any ideas?
prolly bad ground to maf do u have some one u can swap a maf with to see if it runs better
Old Mar 28, 2011 | 06:11 PM
Trini Boom's Avatar
Yeah try the MAF first. Also the sputtering and hesitation could be coil packs..
Old Mar 28, 2011 | 06:42 PM
I'd check her MAF first, then check coil packs and spark plugs.
Old Mar 28, 2011 | 11:21 PM
I need to talk to the other person that worked on her car. The best info I could get out of her (non mechanic speak), is that the coils and plugs were both changed out
What I still can't figure out is why a car would die after the MAF was disconnected. I thought if the MAF was bad, it would run WHILE connected, LOL not the opposite.
@Trini - Mine is a 2K, so I have a different MAF. I'm hoping she gets that cleaner soon as well.
Old Mar 28, 2011 | 11:25 PM
VisciousMo's Avatar
I have a similar female friend though she has a 5th gen and her idle is rough, jumps from 700 to 1700 rpm constantly. Supposedly, she just replaced her throttle body and it didn't fix her problem.
Old Mar 28, 2011 | 11:32 PM
luke95gxe's Avatar
prolly her iacv
Old Mar 28, 2011 | 11:50 PM
mista0406's Avatar
When the maf is taken off the ECU can't process how much air is going through, that's why it shuts down.... But definitly clean the maf sensor and clear any debris from it and also clean the throttle body. If that doesn't cut it then start checking coils
Old Mar 29, 2011 | 05:28 AM
cashoit's Avatar
+1
Once you unplug the MAF, the car should run a lot worse or not at all. If the MAF is faulty, the car may still run but will jus send bad signals to the ECU. '
Def clean MAF and TB per how tos. CHeck IACV and check ground on the MAF and its harness too
Old Mar 29, 2011 | 07:22 AM
hornepirate's Avatar
Ive always heard and been told to never clean the maf even with "MAF cleaner" it can actually cause more damage. If you need a MAF though PM i have one for pretty cheap
Old Mar 29, 2011 | 07:28 AM
3rdGenMaxima91's Avatar
tell me more about that lip!!! I don't feel like paying for a Stillen Lip! email me at jonshivprashad@yahoo.com
Old Mar 29, 2011 | 08:52 AM
Originally Posted by cashoit
+1
Ok I guess that explains why it died. I'd ready on another forum (I thought here), to "unplug the MAF. If it runs smoother, it's the MAF" Hence I could not figure out why it died when I umplugged it. Odd/Bad advice earlier possibly.
Thanks everyone!
Old Mar 29, 2011 | 11:35 AM
cashoit's Avatar
Jus need to be gentle and not drown it. I have cleaned MAFs on 3 different maximas and never a problem. But i think if the wire element is loose then yea u prolly dont want to spray pressurized cleaner on it
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
