5 speed trans issue need input
Old Mar 30, 2011 | 09:28 PM
luke95gxe's Avatar
hey guys an gals i have a 95 5 speed engine has 170xx trans has 300xxx i am have a wierd noise from the trans i have some videos of it its not ips bearing or any suspension componant im thinkin it diff carrier bearings . when i push the clutch in while driving the noise goes away. if its in neutral parked clutch in or out there is no noise. if i let it roll in neutral there is no noise. the noise is very noticable in first gear and in second third i dont hear it. heres the videos there are three
oh clutch is new tob is new
1st vid u can hear it well it like a clicking sound and axles are new all suspension is new
http://s532.photobucket.com/albums/e...0330011759.mp4
2nd vid
http://s532.photobucket.com/albums/e...0330011800.mp4
3rd vid thius one u can here it faint at first then i gave it gas to see if the noise was apparent at higher rpm
http://s532.photobucket.com/albums/e...0330011801.mp4
thanks for ant input ahead of time
Old Mar 31, 2011 | 06:16 AM
njmaxseltd's Avatar
The only way to really know what's starting to fail is to tare it down.
Old Mar 31, 2011 | 07:56 AM
97SEdriver's Avatar
this place is dead
I would just drive it until it explodes if you don't want to tear it apart
Old Mar 31, 2011 | 08:25 AM
phatboislim's Avatar
2nd vid
sounds like the transmission v.inputshaftbearing
same thing happened to mine before it went out...eventually you are going to have a hard time putting the car into gear, then eventually you are not going to be able to put it into gear. you might want to start trans shopping
Old Mar 31, 2011 | 08:37 AM
luke95gxe's Avatar
i was under the impression ips bearing noise is present while the car is idle and u push the clutch in the noise goes away mine does not do thi only while it moving and in gear is the noise present but i have been looking for a used trans
Old Mar 31, 2011 | 09:16 AM
aackshun's Avatar
You can only hear it when the car is idle (cause it's quiet then), but it's making that noise constantly my friend.
It's not that hard to drop a tranny to check it out, just did a tranny swap monday in 2hrs in a parking lot.
When you drop the tranny, you can check your input shaft for play, if it has play it's definitely the bearing, if it doesn't it could still be other bad bearings but atleast it's not the common ISB problem.
You saw my video post in my other thread, check my youtube, if that sounds anything like your car, I would definitely drop the tranny and see if the input shaft has play, and if there are any leaks.
Old Mar 31, 2011 | 09:49 AM
luke95gxe's Avatar
i think maybe i didnt explain well enough i just had this tranny out not to long ago no play on the ips shaft IT DOES NOT MAKE ANY NOISE AT IDLE ONLY WHEN ITS IN GEAR hence i think its in the diff does any one know some one sellin a tranny i need one i cant put the car outa commision for long so i wanna take mine out and rebuild it but i need another one classified arent hitting on much
Old Mar 31, 2011 | 11:36 AM
aackshun's Avatar
Diff it is then and... car-part.com
Old Mar 31, 2011 | 11:43 AM
rmd08's Avatar
I had the same question.
rmd08's Avatar
Good post thanks again guys
Old Mar 31, 2011 | 11:49 AM
luke95gxe's Avatar
good deals at car part and have or do u know anyone thats bought from them?
Old Mar 31, 2011 | 11:55 AM
aackshun's Avatar
It's not a seller, junkyards list their parts on there for people to find them.
Like a craigslist for used auto parts to say...
Old Mar 31, 2011 | 11:57 AM
luke95gxe's Avatar
gotcha thanks man
Old Mar 31, 2011 | 12:18 PM
sterlingmaxima's Avatar
plus one on car-part.com I have gotten very good deals honestly these trannys are not expensive at all might as well just get rid of it worse comes to worse you have an extra for parts.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
