isolate the squeaking
Old Jun 4, 2011 | 07:16 PM
Perseus's Avatar
97 gle squeaks from the front a majority of the time while hitting bumps/uneven road. it can come from either side, or both at the same time.
i read that it's PROBABLY either the sway bar links or bushings. if it could be other things please let me know.
knowing that it could be multiple things, how do i isolate the problem and find out where exactly it's coming from? *please be specific and use the full name of parts or areas when referring to them*
Old Jun 4, 2011 | 07:49 PM
GGENIUS's Avatar
control arms.
Old Jun 5, 2011 | 11:28 PM
Perseus's Avatar
thanks. know of any ways to isolate the problem?
Old Jun 6, 2011 | 01:19 PM
asand1's Avatar
Buy a can of spray silicone lube and spray one bushing at a time.
1 sway bushings
2 control arm bushings
3 sway end links
4 ball joints ( have to puncture rubber boots, at own risk)
5 strut mounts (at top)
Old Jun 7, 2011 | 01:34 PM
Perseus's Avatar
what is that supposed to do/what should i be looking for? most people say to replace the parts, not lube them
Old Jun 7, 2011 | 01:38 PM
neosmatrix's Avatar
I think the poster recomending the lube spray was meant to issolate which part was squeaking. Otherwise your just throwing a bunch of parts at the car.
Your choice I guess
S
Old Jun 7, 2011 | 03:53 PM
TheWhiteWhale's Avatar
If it sounds like a creaky door hinge its probably the inner sway bar bushing. I replaced mine today (2 Moog for 10$ at O'Reillys). If you want to be sure those are the source, place a pry bar between the sway bar and control arm, then pry back and forth. It should be noticeable.
gigabyte
Jan 6, 2017 06:05 PM
SusieQQ
Sep 9, 2015 12:14 PM
MikesChevelle
Aug 7, 2015 05:57 PM
Eric L.
Jan 1, 2001 01:54 AM
nm
Dec 21, 2000 03:49 PM
