oil Drain plug stuck
Tried to change my oil this morning and could not get the drain plug off with any type of wrench...had Pepboys change the oil last time. Wondering if any one else had this problem...or another way of taking the drain plug out? I added a little bit of oil in the meantime since I'm driving up to Somerset and it needs to get changed badly...should I just change the filter until I can get the oil drained?
First off -
Right = Tight
Left = Lose
Make sure you're wrenching in the right direction.
Use a 6 point socket with a 1/2 drive and put some muscle into it.
A quick blast with an impact gun will also do the trick.
Right = Tight
Left = Lose
I'd take it to pepboys and tell them to take it off since they put it on. Do not let them charge you. Make sure you tell them the torque spec is 22-29 ft. lbs. Maybe then they'll use a torque wrench.
Go back to pep boys, find a plug and tell them to change it. I agree cash, noone touches my car but me. Letting another man work on your car is like letting another man **** your wife. (not my quote, but thought its appropriate)
and this too.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
ag90fox
09-09-2015 12:22 PM
