VQ35 swap?
VQ35 swap?
Hey everyone...tried searching around on here but couldnt find much, was wondering what exactly is involved with the 3.5 swap? How much work and what kind of custom work, if any, would i have to do? Also can i use my 5speed tranny and 98 ecu? Thanks in advance for any input.
You'll have to make an account, but this is a good thread.
http://forums.nycmaximas.org/showthread.php?t=19270
For starters, there's a nice sticky in the all motor forum.
http://forums.maxima.org/all-motor/4...swap-info.html
And searching comes up with TONS of good info.
IBTL
IBTL
im deffinetly Gonna be saving up for this swap in the next week or two, i wanna do the full 3.5 swap, 02 IM and some sort of aggressive cams.
but i had a few questions myself, will my stock motor mounts hold the 3.5 and will my stock automatic hold up to the torque from the 3.5? or will i need motor/tranny in all?
The block of the 3.0 and 3.5 are pretty much the same and will bolt right in. If your tranny is in good condition you should be fine but don't expect it to hold up to a full season of drag racing without a rebuild.
That's good to know. I'd rather spend less money and just get the Engine. My 5speed has been rebuilt with an upgraded clutch.
I also noticed the second link K-Ryder posted was from a guy in UT? http://vq35.com/blog/2010/06/vq35-swap/
He said in his blog he'd do swaps in UT for $3000. I was wondering if anyone knew who this person is and if they are still around or on the Org. I would like to consult with them on doing a swap. I'd rather someone experienced do it for a little more then risk pulling my whole car apart and not being able to figure it out.
if i do the 3.5 swap do i have to change out all the timing components? why cant i leave the 3.5 timing chain on? is it cause of the 3.0 ecu?
The 3.0 ECU has no means of controlling the variable timing. The sprockets all need to be swapped for 3.0 because its a different design chain I think. The whole point of the timing swap is to remove the VT.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
