9004 bi-xenon 8000K HIDS
Old Sep 22, 2011 | 07:08 PM
dopey15's Avatar
okay i just installed these HIDS ^^^^
and one problem though only works when i switch on the high beams it worked once when i had the low beams on but didnt switch to hig when i moved the low/high lever
getting to m house the lights went out 0.O but turned on the highs and it worked.....can anyone tell me how to fix this i was thinkning i might have to just adjust or move the grounds cause it came with two grounds and one positive. it also came with canceller/capacitors pleaseeeee im in dire need of help! :/
Old Sep 22, 2011 | 07:44 PM
CrazxyDominican's Avatar
where did you get the HIDs from? it sounds more like a problem in the harness or relay.
Old Sep 22, 2011 | 10:23 PM
You don't need the cancellers/capacitors so remove those. Make sure your grounds are solid. Check all connections, the fuse on the relay and your underhood fuses.
If everything checks out fine, try swapping bulbs from one side to the other to see if the same problem happens on the other side. If the problem persists on the original side, try swapping ballasts from one side to the other to see if the same problem happens on the other side.
That should 100% narrow down the problem.
Old Sep 22, 2011 | 11:29 PM
QT1 5MT AE's Avatar
Gram Lights addict
what is the bixenon mechanism used? does the bulb move up/down or dual filaments?
Old Sep 23, 2011 | 06:33 AM
JNCoRacer's Avatar
Just the tip.
The only 'bi-xenon' 9004 kits Ive seen have a halogen H3 bulb as the high beam. The cancellers/capacitors shouldnt be needed at all like Chris said.
Old Sep 23, 2011 | 08:15 AM
Goomz's Avatar
i had a set of 4300k 9004 bi xenon hids...terrible for non retro headlight users. took em out within a week or something like that last year. MORE glare everywhere cuz the bulb is longer. however i have heard of a coat of paint or something that goes around a part of the actual bulb to reduce glare, but i have also heard of this killing bulb life.
Old Sep 23, 2011 | 08:25 AM
I'm guessing the bulbs move up and down. Those are "true" bi-xenon kits.
Those are hi-lo kits. Bi-xenon kits have bulbs that move up and down.
Old Sep 23, 2011 | 08:39 AM
Goomz's Avatar
well in mine, it seemed to be a magnet in the base of the bulb, and when the high beam is activated, the relay energizes and that would push the bulb forward, not down or up.
Old Sep 23, 2011 | 08:41 AM
QT1 5MT AE's Avatar
Gram Lights addict
OP post pictures of your setup so we can see the wiring.
Old Sep 23, 2011 | 09:25 AM
dopey15's Avatar
im going to try that and if it doesnt work i will take pictures of the connections and see if i can get anymore help :/
Old Sep 23, 2011 | 09:27 AM
dopey15's Avatar
yea it SHOULD move up/down but it only turns on when i turn on my high beams now
Old Sep 23, 2011 | 09:28 AM
dopey15's Avatar
i got them from ultrahid.com
this one to be exact http://ultrahid.com/90bihidki1.html
Old Sep 27, 2011 | 03:53 PM
dopey15's Avatar
bump please help!
Old Sep 27, 2011 | 07:32 PM
Did you check everything I said?
Old Sep 28, 2011 | 05:50 PM
dopey15's Avatar
yes i did
i changed the location of one of the grounding wires and now it works but not high and low beam just stays to a single setting :/ fml
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
