Ported 99 intake vs 00vi and mevi
Old Sep 29, 2011 | 01:00 PM
Dhione's Avatar
Has anyone ever dynoed there car after porting and polishing there intake manifold. and is it worth it.
Old Sep 29, 2011 | 02:01 PM
CrazxyDominican's Avatar
check this.. http://tatanko.boredmder.com/
Old Sep 29, 2011 | 02:49 PM
streetzlegend's Avatar
I know its simple to post a question and wait for experienced users to respond, but believe it or now, when you look for the answer youself on the forum, you end up learning more than what you originally were looking for. So browse around, do some searching, and educate yourself. You'll be glad you did.
Old Sep 29, 2011 | 05:37 PM
MAXIMA_STYLE's Avatar
Well first off...the mevi...which has butterfly valves that open up...similiar to that of a 00vi....are not even close to what youre talking about....those provide slightly mire hp along with full power range through redline...i would find it hard to image just by a port n polish job on the oem intake that would be the case...maybe more power but the cutoffwould still be the same i would think...
Old Sep 29, 2011 | 07:55 PM
allblackmax96's Avatar
ever heard of the golfball dimple theory? porting would help the oem manifold flow better, but polishing not help airflow into the engine, you can port the inside and polish the outside for bling....polishing would only be benificial to the exhaust port on the heads.....
and do some searching, theres threads proving that the 00vi flows better than the mevi, it makes better midrange as well... but alot of people have cold start issue with the 00vi, not with the mevi.....and the mevi is 100% bolt on,and the 00vi requires modification....
Old Sep 29, 2011 | 10:09 PM
Fauken's Avatar
Also, i read that the 00vi also has an idle problem. That it won't idle at the 700-800 range
Old Sep 29, 2011 | 10:44 PM
schmellyfart's Avatar
Some do, some don't.
Mine has no idle problems.
A good amount of 00vi problems are because the installer overlooked something or half-assed the install.
Old Sep 30, 2011 | 04:14 AM
mightyMax95's Avatar
Old Sep 30, 2011 | 06:26 AM
aackshun's Avatar
Originally Posted by mightyMax95
Old Sep 30, 2011 | 07:10 AM
cashoit's Avatar
Originally Posted by aackshun
lol
back on topic tho:
OP, if u looking for an answer as to what mod is better, that is something only u can answer. MEVI direct bolt on, less power. 00VI requires mods but more power and money. Ported and polished IM, nowhere near the power gains.
And SEARCH man, lotta good info here and in the motor section.
Old Sep 30, 2011 | 08:02 AM
aackshun's Avatar
Originally Posted by cashoit
lol
back on topic tho:
Who has actually spent the money and time on the USIM??????
Old Sep 30, 2011 | 08:13 AM
cashoit's Avatar
exactly my point...nobody has!
Old Sep 30, 2011 | 08:18 AM
aackshun's Avatar
Sounds like a problem to me, if people are wasting their time on 3.0's why not work with the USIM.
Old Sep 30, 2011 | 08:48 AM
Kevlo911's Avatar
Kevlo for President
You cannot make long runners give you top end power.
End of discussion...
Old Sep 30, 2011 | 08:50 AM
aackshun's Avatar
But if one was to shorten them
Old Sep 30, 2011 | 08:51 AM
Kevlo911's Avatar
Kevlo for President
One would spend hours on welding and cutting when it would be easier to use the VQ35 im with port matching. It has bigger and shorter runners(flows way more volume of air than the usim).
Old Sep 30, 2011 | 08:55 AM
Kevlo911's Avatar
Kevlo for President
Essentially "polishing a turd"
I had stock idle with the 00vi. If you do it right, you won't have problems. Plus the MEVI gives stock idle as well, still a better option than modding the usim.
Old Sep 30, 2011 | 09:08 AM
aackshun's Avatar
I'd want to fool w/ USIMs cause they're cheap and vast, I'm almost sure there's a better way to peak HP in the 5ks with some work... Again, this was all in the past when before I learned the error of my ways (more like limits of my financials)
Old Sep 30, 2011 | 10:02 AM
cashoit's Avatar
U hit the nail on the head. That is the only reason to try to mod the USIM.
Old Sep 30, 2011 | 10:19 PM
Old Oct 1, 2011 | 01:01 PM
look into what sparks03max did with his stock intake manifold,obvious his is 3.5 but maybe trying something along those lines would work IF you really want to make a usim flow nicely up top...i do think you'll spend alot more time and money trying it,versus just getting an 00vi.....i pulled an entire 00vi setup(upper,lower,tb,injectors,rear valve cover,rear coils,fuel rail,egr guide tube,etc... at the junk yard for 100 bucks..... but again im sure some sort of shorten length runners with a big air "chamber" like sparks did is a good place to start.....
litch
123
Jan 4, 2024 07:01 PM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
