Transmission issues in my Maxi other then Input shaft now :(
Old Oct 19, 2011 | 03:17 PM
S1cTech's Avatar
It whines really bad now. Mostly in 1st 2nd and 3rd when it gets to higher RPMs. I just had the clutch and TO bearing replaced back in Jan and I put that syn amsoil(GL4) everyone talks like its god's oli. And I know my Input shaft bearing has been going what would that have anything to do with the rest of the trans doing this? It is getting so noisy you can hear me down the st and I am worried cause I don't know how much time I have left. I think it was the oil that caused this damage, but I can't be sure, but then again I think whining could happned from a lose Input shaft and I always feel like a looseness between engine tranni like 1-2rpms worth when you hit it.
Bascially I don't know a lot about transmissions like I do the rest of the car. They barely covered Standards in school haha, So basically what I am trying to ask is... How much time would someone have? Can this be fixed? After Replacement of input shaft bearing? how much is it for a new tranni other then 3 grand at nissan which it is probably? I can't buy a new car yet and I don't think she is gonna last much longer. I stopped racing years ago ever since I heard about my IPS bearing going but of course it just gets worse. It is heartbreaking.
history notes: Had my maxi for 6 and a half years and the other issues I had with it is drivetrain(axles) an alternator and crappy suspension(balljoints and tierods) with 3 knock sensors an Ac compressor and now a tranni. lol. I don't think these are the worst as the engine has been mint but she is at 208k and I am scared to buy any older nissan in the future just for the tranni and of couse all I buy is standard(stick)
thanks guys. I hope something can be done and I need it done fast and hopefully not too much over a grand if possible. haha
Old Oct 20, 2011 | 06:50 AM
cashoit's Avatar
the only way to keep it under a grand is to pull the tranny yourself and try to fix it yourself.
Can u do it s1, if u got the tools then yeah man u can do it.
Get the FSM, use the org, and try to tackle the job.
OR, jus find a used tranny and throw that in the car. U can find those in Mass. That would cost under a grand.
Old Oct 20, 2011 | 10:53 AM
dwapenyi's Avatar
I used to have a 98 Max 5 speed. I put in red-line synthetic MT90 at about 50K miles. The car felt great, shifted a whole lot better than with stock nissan fluid. At 110K miles, my bearings were screaming. At 140K miles, I had a shop replace the throw out bearing and the clutch.
That car has since been totalled.
I have another Nissan now (98 I30 5 speed).
I'm sticking with Nissan fluids all the way from now on.
DW
Old Oct 20, 2011 | 11:37 AM
cashoit's Avatar
DW
So u sayin you only replaced the fluid at 50k?
The FSM says to replace every 30k
Old Oct 20, 2011 | 11:46 AM
Maximeltman's Avatar
redline mt90 is one of the best transmission fluids for our rides, that's what I run...
There are always other factors that come into play when transmission fails, you cannot just put it all on the fluids..
op what do you mean by 'feel a looseness between engine and tranny'?
Old Oct 20, 2011 | 11:54 AM
dwapenyi's Avatar
Automatic tranny, right? I thought this was about 5 speed.
DW
Old Oct 20, 2011 | 01:54 PM
S1cTech's Avatar
liek somewhat of a jump or hesitation or if I lift up the clutch a little bit harder its a really tough and hard engage as if something is loose. It is funny cause I always thought it was bad motor mounts until I replaced those then thought it was bad balljoints or lower control arms next would be a bad diff.
Old Oct 20, 2011 | 02:03 PM
S1cTech's Avatar
DW
20k-30k also for gear oil. I've gone probably 12k if that since replacing this oil.
Old Oct 20, 2011 | 02:12 PM
036mtmax's Avatar
actually i tried amsoil/mt-90 and mt-85 in my 03 6mt and drove that car like i stole it and with the mt-85 being the best imo i never had a problem with any of my drivetrain and that was 45k miles of straight abuse. Hey s1c is that tranny that's in there now howling away the same one you were racing with a few years ago ? If it is i would blame all the high rpm shifts and dead launches for the failing trans rather than blaming a synthetic gear oil
Old Oct 20, 2011 | 02:34 PM
S1cTech's Avatar
Well when I raced I didn't do a lot of really hard dead launches. And this was years ago like almost 5. I didn't start having these whine issues until the past year when this oil was placed in when the clutch got replaced. IPS bearing went 3 years ago or so and got louder though out the years
Old Oct 20, 2011 | 02:42 PM
aackshun's Avatar
5MT prices are on the rise, buy new bearings and have a shop put it on, should be as much as a used transmission these days.
Or..... 6mt swap and never have to deal with it again
Old Oct 20, 2011 | 02:50 PM
asand1's Avatar
Lol, your trans is 13 years old and has been raced on, and your blaming the best oil out there? what oil ere you running before, while you were racing?
Hey guys, I've been racing for the past three years on 87 octane. yesterday I put in premium, and threw a rod. Was it the premium fuel??
Just an analogy, I dont think it was the oil. Time for a rebuild.
Old Oct 20, 2011 | 03:50 PM
dwapenyi's Avatar
The fine print says to change every 30K if you tow a trailer or drive your car offroad, correct?
DW
Old Oct 20, 2011 | 03:51 PM
S1cTech's Avatar
yeah but the tranni was fine other then the IPS bearing and just the past 6 months since a year ago I put the oil in, It caused massive whiney. And the gasr analogy is totally different and has nothing do with this because incorrect oil can cause a whine, No gas could blow a rod. So nice fail logic.
dwapenyi's Avatar
Asand1, your point is valid but I'm still sticking with Nissan fluids
DW
Old Oct 20, 2011 | 03:53 PM
S1cTech's Avatar
lol I wish I could just slap in a 6mt, but its pain to find a bellhousing and all that other junk you gotta replace. AKA shifter linkage.
Old Oct 20, 2011 | 05:03 PM
036mtmax's Avatar
Yea man these trannies are hit or miss dude,I think i have the same problem as you S1,I found a cheap cheap full 6mt swap the other day (cough) aackshun lol,Nobody wants to do it for me and im working 60 plus hours a week right now so i know im going to regret passing that up because i called a boneyard near me today and they wanted 1125 for an 01 open diff 5mt...WTF..I can't see myself going from an AE lsd to open diff,Im gonna pull my driver side axle tomorrow and the how much play we got in there..o boy hewego
Old Oct 20, 2011 | 08:39 PM
Nealoc187's Avatar
SLOW
are you really an automotive tech? jesus christ...
Old Oct 21, 2011 | 09:25 AM
asand1's Avatar
But your not using the incorrect oil, your trans is old, and you raced on it. New IPS bearings dont mean squat cause your gears are doing the whining. You took years off the lifetime of your trans by racing and now its dying. Your logic is a fail.
Old Oct 21, 2011 | 10:49 AM
cashoit's Avatar
DW
After u replaced the fluid at 50k, did u ever replace again?
Im tryin to understand why the Spds have such a high failure rate. I want to know if its due to ppl not replacing the fluid at 30k intervals as recommended in FSM.
Old Oct 21, 2011 | 12:56 PM
dwapenyi's Avatar
Nope. Did not change it again. Like the FSM says, change every 30K if you tow a trailer or drive offroad alot. Why anyone would drive a FWD maxima offroad I dont know. And does anyone on here tow a trailer with their maxima?
You know, then again, maybe its me. I drive hard and a similar fate came to a Honda 5 speed I have. 60K of my driving and the gearboxes start singing those whiny blues
DW
Old Oct 21, 2011 | 06:49 PM
S1cTech's Avatar
whaa? I used to be out of highschool. What does that have to do with anything? Never was transmission certified, never covered much on transmissions. What an *** comment to make tho. Props.
Old Oct 21, 2011 | 06:52 PM
S1cTech's Avatar
I raced it 4-5 years ago. And I never raced along time. The transmission was fine for a long time until the IPS bearing started to make sounds. This just started to happen in the past 6-8 months or so. Since changing oil. OR it has to do with the IPS bearing going. That was my question. I am sure it has to do with the IPS bearing but every single gear is what makes me wonder if it was gearoil related.
Old Oct 21, 2011 | 07:24 PM
dwapenyi's Avatar
That is an interesting observation. When my tranny went, it was only 1st gear singing the blues. The other gears were still OK.
DW
Old Oct 21, 2011 | 08:33 PM
Nealoc187's Avatar
SLOW
That question was a result of the incredulity caused by most of your threads, culminating with this one.
Old Oct 21, 2011 | 10:53 PM
MAX/GTR's Avatar
Had similar issues and am currently rebuilding my trams now...ill give you about 3 maybe 4 months before it craps out on you with things getting progressively louder and worse. But I don't recommend driving around on it like that for long if possible. I had no choice I finally lost 1st and 2nd gear and when I cracked mine open I found that the input shafts teeth were sheared off and the inside of the housing was scratched up. Trust me you do not wanna deal with that mess.
Old Oct 22, 2011 | 03:05 AM
S1cTech's Avatar
um ok
Old Oct 22, 2011 | 03:06 AM
S1cTech's Avatar
thanku, that is the best input I have seen on this thread so far.
Old Oct 25, 2011 | 11:14 AM
S1cTech's Avatar
So What I have decided too do because I am low on time therefore low on money, Is I am gonna buy a $500 junky ward tranni. Pop that in and deal with what ever issues that will have later down the road. The thing that sucks is because I have no access to a lift I am gonna pay someone to do this and I gotta pay for them to take out the new clutch and put it in the old tranni. I hope I can find one with Decent miles on it and or no issues cause I only got 1 shot on this. I would like to find an closed diff but I would need to change my driver axle so that would be kind of a pain to have to buy a new axle, plus I doubt I could find a closed diff around here for a decent price anyway. Not like they are that good anyway from what I heard and cause massive understeer in snow. lol
Old Oct 25, 2011 | 11:42 AM
asand1's Avatar
The clutch is actually attached to the engine, so they dont have to touch it. Just have them swap your new TO bearing to the "new" tranny.
Old Oct 26, 2011 | 01:37 PM
S1cTech's Avatar
Well they still would charge me labor for that I am sure, and yeah I also meant my new TO bearing too... etc.
MAXSE5SPD
Sep 17, 2022 04:00 AM
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
dcardello
Sep 3, 2015 11:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
