95 bleeding the radiator ?
Old 12-24-2011, 02:23 PM
luke95gxe's Avatar
ok heres the deal. I had a major crack on my radiator today coolant every where. I went an bought a brand new radiator and thermostat and 50/50 coolant and new rad cap did the swap and attempted to bleed the system. I.E. cap off heat on full blast engine at idle.
now the car just over heats bottom hose is cool top hose hotter then fire cooling fans start off slow then go full blast as the temp rises as they should and both are running i know there is air in the system my question is how do i get it out??
I cant leave the cap off for more than 5 mins before it starts shootin out the top of the radiator and i mean shootin out i know some cars have a air bleed screw to let the air out the system but im pretty sure these dont
any help would be greatly appreciated
luke95gxe is offline
Old 12-24-2011, 04:37 PM
BenL's Avatar
Are you saying the car is overheating or just the hose is really hot? Reason I ask is if the car is actually overheating you could have a broken/stuck thermostat (IIRC, coolant shouldn't shoot out of the radiator with the cap off from cold unless it's getting far too hot, improper flow through the engine would cause this since it's not circulating in enough fresh coolant from the radiator).
It just sounds too much like a stuck/broken thermostat to me, especially if it's showing high temps on the dash since that's on the side where the coolant leaves the engine IIRC... if your thermostat is good you'll see the temps go no further than the half-way mark on the dash when idling since it'll open up fully around that point to allow coolant to freely enter the engine.
For the record I use the same method as you.
BenL is offline
Old 12-24-2011, 06:40 PM
luke95gxe's Avatar
brand new thermostat the car was over heating gauge was very close to the H i got the air worked out now all is well thanks for the replies
Old 12-24-2011, 06:51 PM
tigersharkdude's Avatar
new t-stat may be bad
tigersharkdude is offline
Old 12-24-2011, 11:12 PM
DennisMik's Avatar
You could try getting the front end of the cat up higher, like parking up hill or driving it up on some car ramps. Don't fill the radiator up to the top, leave the upper tank half empty. If there is air coming out of the engine, a full radiator will bubble over.
DennisMik is offline
Old 12-25-2011, 09:05 AM
99zx2's Avatar
stat could be bad (stuck close). did you install it correctly?
99zx2 is offline
Old 12-25-2011, 10:07 AM
Dallas Nissan Enthusiast
darrick's Avatar
always a good idea to put even a new thermostat in a pot of boiling water to make sure it is working , i can tell you how many bad ones i have had over the years
darrick is offline
Old 12-25-2011, 10:58 AM
^^ you just failed hard core
Old 12-25-2011, 04:18 PM
BenL's Avatar
Can't stress this enough... I've always tested thermostats in hot water (200F or so) before removal of the old... if they don't open up fully you just saved yourself some money and hassle.
BenL is offline
Old 12-25-2011, 04:32 PM
maxed_out_99's Avatar
The max needs to have the front wheels off the ground and pretty high in the air to get all the air out and are you sure you didn't install the t-stat backwards
maxed_out_99 is offline
Old 12-29-2011, 03:06 PM
luke95gxe's Avatar
guys i got the air worked out as said in post #3 thanks for the replies
Old 12-29-2011, 03:07 PM
luke95gxe's Avatar
Originally Posted by dswagger
just call nissan
wow
Old 02-03-2012, 04:26 AM
drakkan's Avatar
I am in the middle of replacing my thermostat and quite possibly my water pump too. Can I ask how you bled the coolant to get the air out? Lots of people say to just run the car without the cap on, but I was wondering if there was a bleed screw somewhere or something?
drakkan is offline
Old 02-03-2012, 04:34 AM
boneebone's Avatar
I just ran the car with the cap off until the thermostat opened up and the upper radiator hose was hot. There is no bleed valve.
boneebone is offline
Old 02-03-2012, 04:38 AM
drakkan's Avatar
Glad I'm just not missing it then, lol! How do I know when the thermostat has opened up?
drakkan is offline
Old 02-03-2012, 06:08 AM
boneebone's Avatar
Your upper radiator hose will be hot to the touch, and if you look into the radiator filler neck you will see the coolant circulating. After that just put your cap on and you're good to go.
Old 02-03-2012, 10:22 AM
99zx2's Avatar
blast the heat on high, pop the cap and watch your temp rise. you can get one of those things that you put in place of the cap so it won't be a messy job, and you can add coolant thru it as well. forgot what it was called though.
don't mix coolant with tap water, btw - only distilled.
99zx2 is offline
Old 02-03-2012, 12:08 PM
cashoit's Avatar
Originally Posted by luke95gxe
wow
The kid deleted his post Thats funny.
Yo luke, U prolly jus needed to add more coolant with the cap off.
Glad u got it working man. none of that stuff hard to repalce.
How did the radiator break?
cashoit is offline
Old 02-03-2012, 11:27 PM
CMax03's Avatar
Get a 2 liter plastic bottle and cut the bottom off and removed the radiator cap and stick the bottle in the radiator and fill about halfway up the bottle to make it the highest point of the system and it'll bleed aal your the bubbles out!
CMax03 is offline
Old 02-04-2012, 04:50 PM
luke95gxe's Avatar
yo cash i got it bled the radiator just cracked i also did the thermo while i was at it
Old 02-04-2015, 01:49 PM
maxima95az's Avatar
luke
I'm having the same problem on my 95. How did you fix the overheating plz help
maxima95az is offline
Old 02-09-2015, 01:56 PM
luke95gxe's Avatar
i jacked up the front of the car put the heat on blast let it run with the cap off like that for a bit then took it down a bumpy road
hcarter1112
42
07-18-2022 03:35 PM
Miket2006
03-01-2021 03:55 AM
Unclejunebug
04-02-2016 05:42 AM
jchronis2552
09-23-2015 04:57 PM
RWCreative
09-21-2015 11:01 AM
Quick Reply: 95 bleeding the radiator ?
