Poll:fully synthetic vs. conventional
Old Feb 1, 2012 | 05:19 PM
  #41
tiphawk's Avatar
I've used only synthetic when I got my MAX 3 years ago with 154,000 miles. It's caused no leaks.
Old Feb 1, 2012 | 07:07 PM
  #42
max ride 41's Avatar
Originally Posted by max-r95
He just wanted some attention, he a mr know it all lol
you need to read and be quiet noob. i've seen horror storys with high mileage engines and synthetic, any little leaks became much worse and engines in a couple max's got really hot. i speak from expierience and from what a nissan master tech told me. its hit or miss with synthetic if you have high mileage, period.
Old Feb 1, 2012 | 07:48 PM
  #43
4th_Gen_SE's Avatar
I've been using Mobil 1 Full Syn in my 95' SE since I got it 3 years ago at 196k, never a problem. I went through the whole 9 yards, Seafoaming, cooling system flush and all just for the hell of having it done. I got a little better mpg nothing miraculous, and a noticeably smoother idle, never switching back...Gonna switch my Taurus to M1 soon...
Old Feb 2, 2012 | 03:36 AM
  #44
as stated, if you have no leaks, its a hit or miss with synthetic.
Old Feb 2, 2012 | 04:16 AM
  #45
Mr LoL's Avatar
Originally Posted by cashoit
ehhh i will switch to syn on my next car.
I run pennzoil high mileage 5W-30 every 3k miles
best conventional oil but i use mobil 1 5w-30 in the max royal purple is no good imo the additives in it are meant for organic seals i believe which make regular seals gum up
Old Feb 2, 2012 | 05:21 AM
  #46
dwapenyi's Avatar
Originally Posted by 4th_Gen_SE
..... a noticeably smoother idle, never switching back...Gonna switch my Taurus to M1 soon...
That smoother idle is because you went from dirty oil to clean oil, not because it's synthetic. Same thing happens with dino oil, dirty to clean.
The question should not be whether synthetic is better, it is. People should ask themselves if the difference, especially considering cost and how you take advantage of it with longer change intervals etc, is worth it.
DW
Old Feb 4, 2012 | 05:28 AM
  #47
max-r95's Avatar
I apologize I don't sit on here, I have other things to do. And noob? Lol. Please don't tell me to me quiet, that really hurts. Your twice my age, and Im twice as mature. Take a joke.
Old Feb 4, 2012 | 09:09 AM
  #48
VQMax98's Avatar
I made the switch from dino oil to Mob 1 about a year ago, in that time my car has started having a few seeping leaks from the cam sensor and more recently from the rear main seal. I also used BG MOA a few oil changes ago to clean it out a bit more. I don't believe the synthetic caused the leaks I'm sure they were there all along but since I've cleaned out A LOT of the gunk that has built up in the last 118K miles they have become more apparent. Will I switch back to regular? No, to me it's worth running a cleaner engine and just keeping an eye on the oil level (which I do anyway) and making sure the leaks don't get worse.
Old Feb 5, 2012 | 01:18 PM
  #49
maxed_out_99's Avatar
im just curious where you found that information. i always use royal purple but if its going to cause more harm than good ill stop so far i have been confidently spending 9 dollars a quart for it
Old Feb 5, 2012 | 02:34 PM
  #50
T_Behr904's Avatar
Idk where he got the info about the seals and such, but I have read independent tests where the RP isn't as good in wear and maintaining it's viscosity compared to other synthetics out there.
I believe i've mentioned this before, but I've seen engines that used Mobil 1 since new with 150+ thousand miles on them torn down, and they cylinder walls still had visible crosshatching, and the other parts such as cam and crank bearings still looked new, and everything was squeaky clean looking. Not a sign of any sludge buildup, anywere. Even the oil pan was clean. This sold me on Mobil 1, and every car i've had that I used synthetic in has been Mobil 1.
Old Feb 5, 2012 | 08:42 PM
  #51
I think I may have to switch then. It's defenetly cheaper
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
pjgreek
Sep 9, 2015 09:30 PM
flu2000
22
Sep 2, 2015 07:29 AM
