Need Help got a Cheap Intake for Christmas
I got this for Christmas. It does not have a pipe to extend and looks like it bolts directly on. Any ideas on what I can do to make it better. Overall quality seems good. Any feedback would be greatly appreciated.
http://cgi.ebay.com/ebaymotors/aw-cg...917381&r=0&t=0
Most intakes don't come with piping. The ones you are thinking about are cold air intakes. This should bolt right up where your air box was. If you want you can get custom pipiing run to a foglight hole and put the intake on the end, but its not worth it. It will give you a little more high end power and that's all you should expect. ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
-Cyrus
-Cyrus
Originally posted by Vyrus
Most intakes don't come with piping. The ones you are thinking about are cold air intakes. This should bolt right up where your air box was. If you want you can get custom pipiing run to a foglight hole and put the intake on the end, but its not worth it. It will give you a little more high end power and that's all you should expect.![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
-Cyrus
-Cyrus
maxima297
09-30-2015 03:32 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
09-24-2015 06:56 PM
