car won't start
Old Mar 28, 2012 | 04:27 PM
98max-ima's Avatar
car won't start
hey guys i have a 98 maxima and my story is that i was driving it one night coming back from work and after i came around the corner everything just shuts off and i was still in gear i try starting the car while i was still rolling by popping the clutch but it didn't work too. Now when i try starting the car it'll crank but it won't turn over so the car would start.
HELP!!!!
Old Mar 28, 2012 | 07:26 PM
Turn the headlights on when you try to crank it. Do they get really dim?
Old Mar 28, 2012 | 11:56 PM
whiteSE's Avatar
any codes?
Old Mar 29, 2012 | 11:24 AM
98max-ima's Avatar
No the head lights doesn't get really dim.
Old Mar 29, 2012 | 11:25 AM
98max-ima's Avatar
The only codes are the O2 sensor.
Old Mar 29, 2012 | 11:36 AM
ShocknAwe's Avatar
could be loose terminals if it shut off while you were driving. If they are loose it will drain the battery too
Old Mar 29, 2012 | 12:21 PM
infinimax96's Avatar
Check this first. The terminals will get rusty/corroded and in some cases get so brittle they won't make a connection to the battery. If so you can try cleaning them. If they still don't get good connection after cleaning and look very corroded you can pick up a set of new terminals for less than $10.00. This happened to both my A32's. A simple terminal replacement for both and it's never done it since.
Old Mar 29, 2012 | 01:17 PM
98max-ima's Avatar
I replace both terminal and it still doesn't start.
Old Apr 4, 2012 | 05:03 PM
98max-ima's Avatar
hey guys i was messing around with my car and i got the car to start for a good 5 second until it dies again. And now i got the code for the ignition system circuit. So now im totally stuck and don't know what to do. PLEASE i need some major HELP!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
