P0400 //
Old May 10, 2012 | 09:13 PM
worldwiderecognized's Avatar
P0400 //
Can a leaky muffler ? (rusting/lil hole in it some where) cause this code to come on? Or is it more likely just a clogged EGR tube? I have a 97
Old May 11, 2012 | 01:07 AM
max ride 41's Avatar
search, thats one of the most common codes for our cars
Old May 11, 2012 | 02:43 AM
infinimax96's Avatar
No, a leaky muffler will not cause this.
99% of the time this code comes up because of a clogged EGR guide tube. It can be removed and cleaned and the code should go away. You can find a How to on this under the 4th gen How to's thread. Good luck.
Old May 11, 2012 | 04:49 AM
blacka69's Avatar
Had that code two days ago, removed MAF tp inspect EGR lines and found the line at the bottom of the EGRC-BPT valve had somehow melted. Replaced the hose, it was about 1.5 inches long rest the CEL, and the code is gone. Other than a major component can also be a vacuum leak, I was lucky to find it before i started replacing components, maybe if you know someone with a smoke machine also that can help check your vacuum lines.
DarjeelingRose
Sep 15, 2015 01:20 AM
robsst
Jul 16, 2012 04:21 PM
Infowire
19
Jul 13, 2011 10:19 AM
nitink
38
Apr 4, 2011 05:21 PM
Roman-dude
Jun 26, 2005 01:14 PM
