ATF Flow
Old Jan 5, 2002 | 05:31 PM
max808's Avatar
ATF Flow
Does the Automatic Tranmission Fluid flow,
1. Oil pump > Oil Cooler > Oil Pan
or
2. Oil Pan > Oil Cooler > Oil Pump
From what I can find the flow uses #2. From visual and theory it should be #1.
Old Jan 5, 2002 | 05:53 PM
brubenstein's Avatar
The fluid gets picked up from the sump, pumped through the trans, out of the torque converter (where most of the heat is generated), to the cooler and returned to the sump.
Old Jan 5, 2002 | 07:25 PM
1MAX2NV's Avatar
Number one.
Old Jan 6, 2002 | 12:34 AM
max808's Avatar
Cooler Lines
That means the cooler line on the passenger side of the radiator is the outlet line, since it goes to the AT oil pan. Correct?
TallTom
57
Oct 14, 2025 05:16 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 18, 2015 07:07 PM
Maxboy23
Sep 4, 2015 06:04 PM
Justin Kroll
Sep 2, 2015 11:06 AM
