Maxima in trouble...
Old Aug 7, 2012 | 06:24 PM
  #121
tothemax2003's Avatar
open your intake and check your heads almost sure there is something broken not allowing engine to turn over
Old Aug 7, 2012 | 07:00 PM
  #122
dwapenyi's Avatar
Originally Posted by MaxCanesFan
This is a brand new sensor. I will check the wires.
Ha! And because this electrical part is brand new therefore it must be perfect?
Welcome to the real world, my friend
DW
Old Aug 14, 2012 | 05:43 PM
  #123
MaxCanesFan's Avatar
I checked the sensor again and sure enough it didnt go down. Took it back to advance and got another one. I tested this one and it did as expected. I got excited, cranked it, and it just kept cranking like before - nothing new happened.
I took out a plug and checked it for spark again, and the plug lit up, gas sprayed up as expected. I dont know of anything else to check other then to replace the ECM.
Old Aug 21, 2012 | 06:58 PM
  #124
caseymaxima's Avatar
Perhaps you can get a good used ECM?
This thread is killing me, I really want you to figure this out. I am rooting for you and the Maxima.
Zack
Old Aug 21, 2012 | 07:11 PM
  #125
styliztik's Avatar
I would start exchanging other sensors.
Old Aug 22, 2012 | 08:12 PM
  #126
BIG D MAXX's Avatar
back to basics idk if you checked the oil if its milky engine is done.... just a tip
Old Aug 23, 2012 | 03:47 AM
  #127
Leo_Koneval's Avatar
Hey buddy, Just like caseymaxima, I am hoping really really hard that you can solve the problem and tell us all how you did it.
This is going to be really random but do you have a aftermarket alarm with a remote start by any chance?
This was a couple years ago but when was fixing something under the dash, I saw a black box which was the brain for my alarm. And at the time I did not know my car came with a alarm or even how one looked like so unplugged everything and then my car wouldnt start anymore until I plugged everything back.
Old Aug 23, 2012 | 12:15 PM
  #128
styliztik's Avatar
This is a good point. Even the factory alarm is tied into the starting circuit. I would check the relay/fuses for the alarm and etc
Old Aug 27, 2012 | 09:48 AM
  #129
Alarm
I thought about the alarm system as well. The remote still works and appears to turn everything off, I thought about shorting out the fuse (or whatever you call it by running a wire between between the two points) to make sure it is disarmed. I guess its worth a shot as I had to do this before.
Sensors
Im wondering what other sensors are you referring to. Everything has tested within the natural limits. If I was getting bad readings I would, but not sure I understand the value in exchanging out parts that are testing properly. I realize that coil packs can operate differently under load, but I can't even get the Max started
Engine
Thanks for the idea on the oil, but if the compression test came back as good wouldn't that indicate that the engine is solid? I don't know the answer - so just really asking the question here. I can check the oil - not a big deal - but just wondering what I am looking for.
Appreciate all the cheering and yes I hope to find the issue as well. I thought I had a good line on a used ECM, but proved to be a bust. Going to try and find one this week since I am back home. The poor Max just keeps looking at me - cant tell if she is saying Fix Me or Leave Me Alone - seems like the latter since she doesn't want to start and not sending any signals. Just like a woman (LOL)
Old Aug 27, 2012 | 04:51 PM
  #130
luke95gxe's Avatar
Alarm
Sensors
Engine
hit chesterfield auto and then circle auto. they also have a new junk yard open to the public at woodfin in chesterfield right beside southside speed way. they always have a lot of maxes they used to just deal in jeep an honda parts but like 2 years ago the started to get other makes an models and let u in to pull the part yourself
Old Sep 14, 2012 | 08:05 PM
  #131
Any updates?
Zack
Old Sep 16, 2012 | 12:35 PM
  #132
darrick's Avatar
Dallas Nissan Enthusiast
Did u fix this prob ? I'm rooting for you bro
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
