lowering my car
#42
#46
i live in trenton and have been to NYC plenty of times so i know that the roads are very similar. havent been taken care of for what looks like a hundred damn years. people around here have to avoid certain streets, routes, ect when they go that moar low
#51
OK. That's what I was thinking.
#53
Most alignment shops just read the computer for Nissan alignment specs. Nissan says you are not supposed to adjust camber. When the shop sees this they dont adjust the bolts.
I had camber bolts from Summit Racing. They kept backing off and screwing up my alignment. After the 3rd attempt i thought about it and asked the guy if he adjusted camber bolts. He didnt even notice they were there!
I promptly took off the cambers and now the car is straight as an arrow!
#54
I have Tokico blues and they straight. I was thinking about switchin to illuminas but in terms of dampening they seem about the same. Or what setting do u have the illuminas set to? I have hrd on setting 2 its stock soft
#55
Im going to advise against the camber bolts.
...food for thought
#56
Agreed. thats why i had gotten the bolts in the first place.
The way my mechanic had initially installed the bolts. the fronts were crazy negative!
I have removed and realigned now everythin in spec. but ima keep an eye out for abnormal wear.
I do remember doing research and ppl saying that the bolts were necessity if you go 2"+ drop. Im thinking for my mild drop its fine w/o the bolts.
#57
I have the fronts on 3 and the rears on 5. I cant even carry like 2 people in the back because it rubs when i hit a bump.
#58
Sounds like you might have extreme wider tires or spacers......you may need to roll your fenders......or limit how many people you ride in your car....Are you a taxi??????
Lakersallday24
06-16-2019 01:35 AM
soon2ownmax
08-13-2015 02:19 PM
laparka66
08-06-2015 09:36 AM
