Breaks!
Old Sep 3, 2012 | 09:29 AM
sirposted's Avatar
Breaks!
When my car is running the left front break is not working when i step on the break when its off and been sitting for a bit it feels normal but when running it got this loose feeling. i took the caliper apart and the piston goes in and out running and not running i bleed the breaks i had the same outcome...nothing the pads and the roters are brand new, i was thinking about replacing the master cylinder
95 Maxima
98 motor/tranny 5 speed
Old Sep 3, 2012 | 10:44 AM
T_Behr904's Avatar
Originally Posted by sirposted
When my car is running the left front brake is not working when i step on the brakes when its off and been sitting for a bit it feels normal but when running it got this loose feeling. i took the caliper apart and the piston goes in and out running and not running i bleed the brakes i had the same outcome...nothing the pads and the rotors are brand new, i was thinking about replacing the master cylinder
95 Maxima
Fixed...
Old Sep 3, 2012 | 11:15 AM
sirposted's Avatar
thanks for the help
Old Sep 4, 2012 | 07:50 AM
Quickywd01's Avatar
Old Sep 4, 2012 | 08:32 AM
ShocknAwe's Avatar
Seals could be bad. Get a rebuild kit first before you go right to master cylinder
Old Sep 4, 2012 | 01:56 PM
njmaxseltd's Avatar
How do you know the caliper isn't working? Do you have a hard pull when applying the brakes the first few times? I don't understand the lose feeling?
If the caliper wasn't working, you'd get one hell of a pull in the steering from the side that's working when you applied the brake. Is that what's happening?
Old Sep 4, 2012 | 07:36 PM
CMax03's Avatar
Wowwww what's up with the spelling lately?
Old Sep 4, 2012 | 08:48 PM
CMax03's Avatar
Here are some good brakes!!!!!!
http://youtu.be/DQpq1_pfIgk
Old Sep 5, 2012 | 01:31 AM
max ride 41's Avatar
gimme a break, break me off a piece of that kit-kat bar!!!
Old Sep 14, 2012 | 10:48 AM
sirposted's Avatar
i took it for a lil test drive up the block at a very low speed (about 10 mph) i went to hit the brakes the pedal goes half way to the floor i'm getting no compression and i only feel the right wheel lock up if i put it to the floor i slide. I bring it back to the house i take off the left wheel there's still rust on the rotor, i take apart the caliper, compress the piston back and have my friend pump the breaks the piston comes out fine i also don't see fluid leaking from any of the hoses
Old Sep 14, 2012 | 12:06 PM
M in KC's Avatar
How have you confirmed you have all the air out of the system. Simply depressing the brake pedal until the pistons start to move in the caliper is not sufficient.
Old Sep 24, 2012 | 06:20 PM
sirposted's Avatar
So i bled the brakes with a clear hose and a bottle full of fluid, the right was fine no bubbles the left was squirting fluid and not sucking up any fluid from the bottle. I also pulled the master off the booster and looked inside didn't really see any new fluid inside. Checked all the lines everything was fine no leaks. Again this problem only happens when the car is running.
also car has no abs
Old Sep 24, 2012 | 06:23 PM
Rods03Max619's Avatar
**** reminded me I was suppose ro switch my pads maybe tomorrow....
Old Sep 25, 2012 | 09:57 AM
sirposted's Avatar
: l .................................................. ......i like your wheels
Old Sep 25, 2012 | 11:37 AM
andrewmac's Avatar
Fixed...
They're brakes until they stop working, then they're breaks.
Old Sep 25, 2012 | 12:25 PM
max1008's Avatar
Did you give any resistance to the caliper when he pressed the break..wait brake? Are the pads stuck in the bracket....
Old Sep 25, 2012 | 12:26 PM
cashoit's Avatar
only in the 4th gen section lol....
Um, i wd say proportioning valve for the brakes is done.
Old Sep 25, 2012 | 11:04 PM
sirposted's Avatar
ware is the proportioning valve located and ware can i find a new one
Old Sep 26, 2012 | 07:18 AM
GGENIUS's Avatar
can you type a sentence thats legible or no?
Old Sep 26, 2012 | 09:03 AM
CallMeThatOneGuy's Avatar
Lawlz
Old Sep 26, 2012 | 09:47 AM
sirposted's Avatar
listen i'm sorry for the spelling can i get some help please
James92SE
142
Jan 2, 2024 09:23 AM
D Mason
Jun 21, 2016 04:43 AM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
jchronis2552
Sep 21, 2015 05:52 AM
