No CEL Misfire issue
Old Sep 15, 2012 | 08:05 PM
Xfactor22's Avatar
hey people,
My car has been pissing me off lately, i havent thrown a code in over a year and there is no way of telling what issue i have. The spark plugs are about a year old and i have no real mods on my car that would effect it.
My issue is what seems to be a misfire.. but it isnt, my coil packs are good and im getting no codes. When im sitting still it sounds identical to a misfire, just kinda bogging down every second or two and when i start moving it kinda holds me back at the time the misfire would be happening. Like something isnt breathing right. i dont understand what it is.
I have an older CAI which never had any problems and i have a straight pipe exhaust which i have had for a while and didnt give me problems.
My car has 173,xxx miles on it and its 5sp. It started about 3 months ago and just gradually gets worse. Today it was happening and my car was back firing unnecessarily, at unusual RPM's, it wasnt making sense. My car just got inspected and passed emissions.
So the question is, what can cause a misfire like issue without throwing a code?? Anyone please help. Anything to point me in the right direction. Thanks!!!
~Francis
Old Sep 16, 2012 | 07:57 AM
Xfactor22's Avatar
Anyone know what can throw a misfire without throwing a code??? Anyone
Old Sep 16, 2012 | 08:03 AM
Kevlo911's Avatar
Kevlo for President
i have seen bad coils w/o a cel
when it is misfiring, unplug each coilpack one by one and see if it makes a difference, if it doesn't - you found your problem
Old Sep 16, 2012 | 08:55 PM
Xfactor22's Avatar
Oh ok. Didn't know they could be bad without throwing a code. I will definitely check, thanks kev
Old Sep 16, 2012 | 09:34 PM
Amerikaner83's Avatar
your CEL does work, yes? Just want to make sure.
Agree with Kev, unplug coils one by one at idle. The unplugged coil that does NOT change the idle (or changes idle the least) is your bad one.
Old Sep 17, 2012 | 11:21 AM
bobflood's Avatar
You should also check to make sure that your injectors are all working. A bad injector can feel like a misfire (i.e. no explosion in that cylinder), but since the plug is still firing you don't get a misfire code. Just fixed up a lady's Sentra at our Car Care Ministry with this problem. We pulled spark plug wires to ID the bad cylinder, but when we tested the spark it was fine. Replacing the injector fixed it right up. Good luck.
Old Sep 17, 2012 | 04:39 PM
Xfactor22's Avatar
Thanks, i was thinking injector but i wasnt sure again if it was possible to have a bad injector and not catch a code. As of now what i am going to try to do is a tune up. New coil packs, new spark plugs, and injectors. I will try that and see if it goes away. Thanks for all the help
Old Sep 18, 2012 | 04:51 PM
fat_kid's Avatar
try some injector cleaner too, never can hurt
Old Sep 18, 2012 | 05:28 PM
dwapenyi's Avatar
THIS...kinda
I've always been under the impression that my car had a soon to be failing ignition coil. Once I did the TC-W3 thing, all symptoms were gone. In other words, I had a sticky fuel injector.
Do the TC-W3;
http://forums.maxima.org/general-max...troke-oil.html
DW
Old Sep 19, 2012 | 06:36 AM
cashoit's Avatar
Did someone say injector cleaner???????? lol
Chevron Techron man...best on the market. I seen it do wonders on older cars. Completely clear CEL issues.
See sig
Old Sep 19, 2012 | 08:44 AM
njmaxseltd's Avatar
A failure on the secondary side of the coil cannot be seen by the ecu. It has to be detected by the crank sensors signals.
Same with a fuel injector. Mechanical failure or plugged injector cannot be detected by the ecu. The crank sensor signals help detect these type of misfires which often go undetected until the condition gets worse.
Old Sep 24, 2012 | 05:58 PM
RushNatU's Avatar
Sometimes injectors just fail and cant be cleaned. Your best bet is to grab a few at a junk yard for a few bucks. The front three take like two minutes to change and you could get lucky if its one of those. Worked wonders for my misfire problem.
Old Sep 24, 2012 | 06:01 PM
MaxFiyah's Avatar
i had really bad misfires on my 00 max real hard rumble till the point it wasnt driveable its a coil most likely if your gonna change coils maybe change the sparks with platinums goodluck
Old Sep 25, 2012 | 09:04 AM
Xfactor22's Avatar
See sig
So its been two days, and i used that Chevron Techron stuff, and all the symptoms are gone, it was a pretty regular occurance and now my idle is fine and driving is great too! Best money i spent on my car! Great advice!
Old Sep 25, 2012 | 03:27 PM
theblackone3.5's Avatar
the miss will come back when you fill up for gas. It works great until you fill up again. Its a temporary fix, but its not a permanent fix.
Old Sep 25, 2012 | 03:49 PM
Xfactor22's Avatar
What if it doesn't return? I was near E when I put the stuff in and filled up. Are you suggesting if it returns that i need to change my injectors??
Old Sep 25, 2012 | 04:21 PM
MAXIMA_STYLE's Avatar
Yes thats what hes sayin.... if it comes back it means your injector is too far gone to save it ...im in the same boat bro...been chasin this "misfire" problem for a month
Old Sep 25, 2012 | 11:27 PM
Xfactor22's Avatar
did you also use injector cleaner and it came back or whats your situation? Is there a chance it wont come back?
Old Sep 26, 2012 | 01:13 AM
maxinout93's Avatar
like someone else said the misfire will come back, mine did. I used 2 cans of b-12 on 2 tanks of gas, soon as I got near empty the misfire came back worse than before. I even tried seafoam and it didn't help the misfire issue, somtimes fuel injector cleaners don't work on a dead fuel injector. I even used chevron techron as a last resort, still didn't unclog the injector. my car had a leaky rear valve cover gasket and leaking spark plug seals that were getting oil on my coils boot. the misfire all of a sudden just started one day, so I checked all coils and number5 wasn't doing anything, I switched them around and the coil was firing on the other cylinder but not on 5, so to rule out coils I switched again, still same result. ended up being a bad injector, I just replaced it today along with the rear valve cover gasket ect cleaned everything put it all bak togather, and misfire and hesitation are gone on my 95!!
Old Sep 26, 2012 | 12:19 PM
Ive used f.i cleaner and b12 chemtool... both helped...until new gas in tank... mine is cylinder 5 with a code...plugs and coils all good...mines gotta be a dead injector...
Old Sep 26, 2012 | 05:56 PM
maxinout93's Avatar
yup mine was number 5, I got tired of it not running right because I could feel the misfire throughout the driving range and it kept getting worse, plus gas mileage was suffering. I took the time to clean and unclog. everything while I had the lid off. now she purrs like a kitten
Old Sep 27, 2012 | 10:24 AM
Fml... guess ill be gettin new injectors asap...
Old Oct 2, 2012 | 11:12 PM
Xfactor22's Avatar
Right there with you
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
