99 clutch problem, clueless
Old Oct 1, 2012 | 08:14 AM
Xfactor22's Avatar
VIDEO ON POST #4!
So my 99 clutch has always been annoying, having a small leak somewhere so i have to constantly put brake fluid in the little container for the clutch, so i can actually use it, last night it did the same thing only the clutch was a bit softer than normal and when i pulled over to put the fluid in there was a puddle of the fluid on my splash guard and on the ground, and the clutch wouldnt work after that. we sort of located the leak by putting more in an found where it dripped, its at an easy location but i still have never dealt with this stuff before.
What the heck do i do now? Im pretty good with my car, ive done everything to my car myself including repairs, but ive never done anything with the trans or clutch, so im immediately lost.
can i replace the part that was leaking and do i have to bleed something like i do when changing brake lines. I just dont know where to start in this situation, maybe you guys could point me in the right direction??
Anything will help!!!!
Old Oct 1, 2012 | 09:01 AM
cardana24's Avatar
Blown
Can you tell us what part is leaking? It's either going to the master cylinder (where you are pouring the fluid), the line going from the master to the slave, or the slave cylinder (mounted on the bell housing). Yes, you can replace the part is leaking.
Old Oct 1, 2012 | 11:13 AM
Xfactor22's Avatar
I found the leak I am goin to post pics ASAP and a video. If you can further assist me after I post them I would be so grateful!
Old Oct 1, 2012 | 04:34 PM
Xfactor22's Avatar
Here is a video of what happens when i push the clutch...
sorry for the crappy video, its on my phone. What steps do i take to replace the hose and bleed the system if i have to.
Old Oct 1, 2012 | 05:42 PM
JNCoRacer's Avatar
Just the tip.
You can either replace that hose with an OEM one or replace it with a stainless braided one. When you go to bleed it I'd suggest getting a hand pump vacuum bleeder if youre doing it all by yourself.
Old Oct 1, 2012 | 08:42 PM
Xfactor22's Avatar
Well I have someone else doing it with me, I just dot know where to start with bleeding it. Any more specific advice?
Old Oct 1, 2012 | 08:53 PM
FortuneJr's Avatar
Get stainless steel and have only one bleeder.
Or go oem and have to bleed both lower then upper bleeder valves. Start with the bottom one closer to where the slave cylinder is and then move your way up to the upper valve. Always keep an eye on that fluid level.
Used this photo from the .org when I had to bleed my system.
Old Oct 1, 2012 | 10:28 PM
Xfactor22's Avatar
Picture is very helpful, with stainless which one do I bleed? you said I only have to bleed one. Where can I get a stainless line to fit exactly
Old Oct 3, 2012 | 10:21 AM
[s3]'s Avatar
This,
http://www.ebay.com/itm/1994-2001-Ni...3a0086&vxp=mtr
And bleed from the lower bleeder, the upper bleeder will be rendered useless and can be removed.
Old Oct 3, 2012 | 11:31 AM
asand1's Avatar
Originally Posted by [s3]
This,
I could be wrong, but that looks like the wrong line. Too short and wrong fitting for one piece line.
I think this is the one you want.
http://www.ebay.com/itm/95-01-Nissan...ht_2190wt_1006
Old Oct 3, 2012 | 11:33 AM
[s3]'s Avatar
"Pictures are for reference only"
I bought one from them and installed it, works fine.
http://forums.maxima.org/group-deals...tch-lines.html
Same people
Old Oct 3, 2012 | 12:03 PM
JNCoRacer's Avatar
Just the tip.
Thats the one I bought. Works great.
Old Oct 3, 2012 | 12:07 PM
[s3]'s Avatar
Same people
Yup correct, not sure why they have them for 94 to 2001 and 95 to 2001
aackshun's Avatar
If you're doing any type of hydraulic clutch system work on the Maxima... Replace the whole line w/ a SS braided line.
The LONG one and not the short one.
Old Oct 3, 2012 | 01:00 PM
asand1's Avatar
this was the point of my post. The first link does not state one piece, I believe it only replaces the upper and utilizes the upper bledder as well.
Old Oct 3, 2012 | 05:59 PM
Xfactor22's Avatar
Well I don't have time to buy one online but will use the links as reference web I go to autozone or nappa, I'm attempting to repair it tomorrow probably by myself. So we will see how it goes, thank you everyone for your input thus far
Old Oct 3, 2012 | 06:01 PM
asand1's Avatar
Many napas can build this line, but be prepared to pay $75+
Old Oct 4, 2012 | 01:34 PM
Xfactor22's Avatar
Ok so no one has that line, or anything like it, the long one replaces the whole thing?? Getting rid of the upper bleeder too?? From the fill up cylinder to the slave cylinder right?
Old Oct 4, 2012 | 04:38 PM
asand1's Avatar
Yes, the long one goes from the master cylinder directly to the slave cylinder.
Old Oct 5, 2012 | 06:59 AM
slfalco's Avatar
when my lower hose was leaking, I was only able to find a new one at either the dealer (which I did not choose) or online (I think I used partsgeek.com).. bleeding is also a challenge, best to use something that sucks fluid and air out (like Mityvac tool).
Old May 31, 2013 | 05:17 AM
TagsCustoms's Avatar
Hey guys I really need some help and insight so I bought a 99 maxima about 2 months ago I really haven't been driving the car aggressive or doing any burnouts and the clutch started going last week so I bought a 6 puck clutch and had it replaced. None the less on my way home the clutch felt a lil low to me so I decided I was going to bleed the line. I cracked open thw top bleeder thats on the strut tower and my clutch pedal sank and will not come back up at all unless I pull it up with my hand I changed my slave and tried bleeding the slave and master cylinder and not for nothing my clutch pedal will come up everytime I pull it up by hand and push it down it just stays down I really need some help thanks.
Old May 31, 2013 | 08:07 AM
bobflood's Avatar
First thing I would do is replace all the OEM clutch to slave hydralic plumbing with the one piece stainless line from link below:
http://www.racetechperformance.com/P...10%2D0154%2D42
Chance are the flexible parts of your present clutch line are leaking/failing. Also, +1 on an earlier post that suggests using a hand vacuum pump to bleed system - it's a LOT easier than the two person pumping the pedal method.Good luck.
Old May 31, 2013 | 09:01 AM
Thanks alot ill try that
Old Jun 2, 2013 | 09:51 AM
99zx2's Avatar
you just need to keep bleeding it. get a helper or buy a speed bleeder valve - awesome little thing to have for a 1-man job.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
