Overheating at stop light?
Old 10-15-2012, 04:24 AM
Maximeltman's Avatar
My girlfriend's Maxima, 1995, was running pretty good for the year that she owned it. Yesterday, she was complaining that the temp needle stays in the middle while driving, but when at a stop light it goes up to 3/4 the way, then goes back down when driving again...I'm thinking this a sign of a bad thermostat? Can anyone else throw in some advice?
Maximeltman is offline
Old 10-15-2012, 04:41 AM
styliztik's Avatar
Probably low on coolant.
styliztik is offline
Old 10-15-2012, 05:27 AM
njmaxseltd's Avatar
Check coolant level and fan operation.
njmaxseltd is offline
Old 10-15-2012, 06:49 AM
Shift_A32B's Avatar
Check for low coolant. If coolant if fine, check your fans. Turn on the car, wait or drive around until you reach operating temperature. Leave the car on, open the hood, go outside, wait until the fans kick in (have your girlfriend keep an eye out on the temperature needle). If the needle starts creeping up and your fan don't kick in, then you found your problem. Turn off the car before the car starts overheating. Report back.
Shift_A32B is offline
Old 10-15-2012, 06:49 PM
yes yes ya'll...I will do as suggested. Thanks brothers!
Old 10-15-2012, 08:28 PM
SLOW
Nealoc187's Avatar
it's the sign of radiator fans that aren't kicking on...
Nealoc187 is offline
Old 10-15-2012, 08:30 PM
Snypa's Avatar
Maximeltman? Where is the power steering pump I purchased from you? I have messaged you and written in the thread to no avail. Please let me know whats going on. I need this asap. Thanks
Snypa is offline
Old 10-15-2012, 09:42 PM
ShocknAwe's Avatar
like nealoc said, if its just at idle then your fans arent working. Bring your car up to temp, pop the hood and wait for the fans to come on. If they dont fairly quickly at idle then you need new fans. Easy job, literally 2 bolts I believe or maybe 4
ShocknAwe is offline
Old 10-15-2012, 09:49 PM
asand1's Avatar
Or relays or fuses.
asand1 is offline
Old 10-16-2012, 06:37 AM
I shipped it out...you should get it very soon! USPS. I lost track# but I'm posting on here to let you know I'm not scamming you bro.
Old 10-21-2012, 07:54 AM
nycmaximas member
BORQUA79's Avatar
I had the same issue. It turned out to be my fans. I bought a new fan assembly and it worked like a charm. It's not a big deal to change either. Good luck.
BORQUA79 is offline
Old 10-22-2012, 09:48 AM
yea thanks brothas! She was hella low on coolant, there wasnt even any pressure in the hoses...its working now though, she had a bad rad cap.
mvm062
11-30-2020 09:00 AM
Maxima30
09-07-2015 06:13 PM
MidnightMaxima_22
09-06-2015 01:18 PM
mikebla
09-03-2015 05:37 PM
crazyespn
09-03-2015 01:30 PM
Quick Reply: Overheating at stop light?
