Suspension Questions?
Hey guys I am riding a 96 SE and my shocks are completely shot. Riding on pretty much just springs and I was going to replace my rotors/pads which then led to "oh well I'll just do it all at once." Im thinking of Tokico blues with some springs (megan, h-tech, tanabe) somewhere along those lines for a ~1.5 drop. I hear blues with s-tech is super rough. I would love full coilover or even illumina/agx but I am broke. I am going to replace the boots/bumpstops but I have a question that I cant seem to find a definite answer for. 1. Is it necessary to buy new front shock mounts as I have seen people do, and 2. Do I need to buy the seats/cushions that go on top and bottom of the spring? Any advice on the subject in general is much appreciated as this is the first time I have ever worked on suspension. Thanks in advance
You don't need to replace anything that isn't worn out. Therefore, remove the assembly from your car, tare it down and inspect. Replace what's necessary, rebuild and install.
I don't suggest the blues be coupled with anything other then H&R's, Progress or H-Tech's. S-Tech's are junk, leaving you with no suspension travel.
You're always looking out for me ShocknAwe!
Thanks man.
BTW, my car has been lowered with different spring and possibly strut. Would the OEM boot still work even though it may be different? I would think it would just compress more right?
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
I been running with Sprint spring for over 12 years and I need to replace my front struts.. running on KYB AGX now. I wanna keep the 2 inch drop I have now with Sprint springs. Any recommendations on struts with Sprint springs?
I just wondering if the shock is long gone and you just ride on spring, how would you be able to pass the safety inspection? Here is PA, you will certainly fail the inspection like in my case that the rear shock is gone.
I was looking for a good suggestion on new struts with my current Spring spring.
pears
09-18-2015 05:25 AM
Violator
09-09-2015 10:14 AM
