Hard start problem
Old Mar 27, 2013 | 04:22 PM
raider6109's Avatar
Hard start problem
I replaced my starter and the car sometimes is hard to start now. Once started, runs quite and still gets 30 mpg. Every sensor is plugged in and hoses are reconnected. Anyone have this problem
Old Mar 27, 2013 | 04:25 PM
BlackThornDemon's Avatar
Check the batter and terminals.
Old Mar 27, 2013 | 04:34 PM
dreek96max's Avatar
check your grounds also the ground under the hood where fuse box is....make sure free of corossion and the grounds to the fuel injectors..
Old Mar 27, 2013 | 05:37 PM
2brosgixxer's Avatar
Number one question that should have been asked...Any Codes/Check Engine Light?
Old Mar 27, 2013 | 05:50 PM
raider6109's Avatar
Yes, it has a maf and a knock sensor code
Old Mar 28, 2013 | 12:12 AM
maxinout93's Avatar
make sure you plugged the maf back in, also check the start signal fuse under the dash, sometimes they can look good and still be bad I believe that its a 7.5 amp fuse.
Old Apr 4, 2013 | 11:39 AM
raider6109's Avatar
I used connector gel and cleaned the battery terminals. Got better but sometimes hard start. Random when its hard to start. Most of the time it starts up instantly
Old Apr 4, 2013 | 01:07 PM
raider6109's Avatar
I cleaned the main ground and the ground on the drivers side fender. Changed some fuses but still sometimes hard to start
Old Apr 4, 2013 | 02:20 PM
luke95gxe's Avatar
have you checked to see if your ignition switch has play in it
http://forums.maxima.org/4th-generat...lots-pics.html
Old Apr 6, 2013 | 11:29 AM
raider6109's Avatar
Seems to have no play.
Codes
P0325 knock sensor
P0150 air fuel sensor
P0100 maf sensor
P0105 maf sensor
Old Apr 6, 2013 | 03:34 PM
TurboA32's Avatar
did you have this problem before you changed the starter?
Old Apr 6, 2013 | 05:05 PM
kingofny1997's Avatar
It's crazy I'm getting this problem here and there too, most of the time starts right up, and once Ina blue hard to start, when I turn the key it just does like a jut jut and doesn't turn on, then I'll go and remote start it.. And it never fails to turn on...what's up??.
Old Apr 6, 2013 | 07:20 PM
luke95gxe's Avatar
your ignition switch if u can remote start no problems then its ur switch
Old Apr 6, 2013 | 07:52 PM
Trini Boom's Avatar
P0100/P0105 MAF Sensor is your problem. DId you reconnect it and also did you damage harness or sensor in any way??
Old Apr 6, 2013 | 08:16 PM
TurboA32's Avatar
It could be the starter. I know people had this kind of problem with the aftermarket starters and when they put the nissan starter in problem went away.
Old Apr 6, 2013 | 09:04 PM
luke95gxe's Avatar
when I turn the key it just does like a jut jut and doesn't turn on, then I'll go and REMOTE START IT.. And it NEVER FAILS to turn on...what's up??.
not the starter if it starts every time no fail from the remote start there is a issue from ignition
Old Apr 7, 2013 | 06:26 PM
raider6109's Avatar
Added a ground from the starter to the battery, fixed the problem
Old Apr 12, 2013 | 11:41 AM
crazy97's Avatar
I was just going to suggest that.
02PearlSE
Oct 7, 2015 02:12 AM
Tha'-Max
Aug 30, 2015 01:14 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Gsantos79
Aug 8, 2015 07:41 AM
