nagging issue
Old Apr 28, 2013 | 07:47 PM
kk_kalina's Avatar
nagging issue
ok guys so my starter started going out so I replaced it with a BRAND NEW (not rebuilt) starter well it was working great then one day I went to start it and it didn't engage but the starter kept getting power and spinning (not engaged) even after I took the key out so I unhooked the battery and sent the starter back got a different one thinking it was a started issue well I got it in and the very first time it did the same thing except I unhooked the battery and when I hooked it back up it didn't start back up, since then its been working fine until today I went to start it and it didn't keep running it stopped when I let the key go but it was spinning and not engaging I tried again and it worked does anyone have any idea whats going on... last thing I want is to be stranded
Old Apr 28, 2013 | 08:02 PM
Aflion's Avatar
Hmmm. Clean your ground points. If you didn't have a problem before you replaced the starter, get a reman or used starter. I don't trust anything that isn't factory for a good reason.
Posted from Maxima.org App for Android
Old Apr 28, 2013 | 08:04 PM
kk_kalina's Avatar
grounds are good already did that im leaning towards it being ignition switch
Old Apr 28, 2013 | 08:19 PM
Aflion's Avatar
Is there an engine code for anything?
Old Apr 28, 2013 | 08:23 PM
kk_kalina's Avatar
no engine codes all clear
Old Apr 28, 2013 | 08:41 PM
Aflion's Avatar
Ignition switch could be it, but the starter still getting power to it is a curveball. Especially after the key was out. Sounds like there might be a short somewhere in the ignition system.
Old Apr 28, 2013 | 08:48 PM
kk_kalina's Avatar
im thinking that might have something to do with my ignition relay I might replace it maybe its sticking or something
Old Apr 28, 2013 | 09:01 PM
Aflion's Avatar
Well, a relay is always easier to replace than ignition switch. Haha. Hopefully it solves your problem.
Old Apr 28, 2013 | 09:07 PM
kk_kalina's Avatar
in the event I need to change the ignition switch does anyone know how?
Old Apr 28, 2013 | 09:13 PM
Fakie J Farkerton's Avatar
http://forums.maxima.org/4th-generat...lots-pics.html
Old Apr 28, 2013 | 09:20 PM
kk_kalina's Avatar
thank u sir
Old Apr 28, 2013 | 09:57 PM
thank u sir
Your welcome! Check out the stickies for our gen.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
