someone help me with the MAF
Old Jan 14, 2002 | 01:19 PM
Soon2BMaxed's Avatar
well me and my dad made a home-made intake adapter yesterday and when we went to screw the MAF into the adapter i took off the little part on the side of it where the harness plugs into it. well when we put it on the car and plugged everything back in the engine was hesitating and i couldn't hit the gas or it would stall. so i took the intake apart and put everything stock back together and in the car. it did the same thing so i read the ECU and it gave me the 4-1 and the 1-2 codes which are the Air Intake Temp sensor and the Mass Air Flow Sensors. when i took the little part of the MAF off and put it back on did i mess it up? my nissan dealer wants $488 for it. if theres somewhere cheaper PLEASE post it. thanks
Trevor
Old Jan 14, 2002 | 01:25 PM
RedMax95's Avatar
Re: someone help me with the MAF
Trevor
there are 3 metal pieces that have problems when taken apart, a common fix involves extra solder on the connections
Old Jan 14, 2002 | 01:32 PM
Re: Re: someone help me with the MAF
yeh i saw those pieces, so just put some solder on the end of them, put the cover on, and screw it back together?
Old Jan 14, 2002 | 01:50 PM
RedMax95's Avatar
Re: Re: Re: someone help me with the MAF
as i understand it the connections when replaced dont work real good, solder can get you a better connection bc it has a greater area to connect, dont get the solder from one to touch another, if i were u i would give these guys awhile to respond and give you a confirmation of this
Old Jan 14, 2002 | 01:56 PM
Re: Re: Re: Re: someone help me with the MAF
ok thanks! but this thing is fuct up either way, so i think i will go ahead and try to solder it and hopefully that will do it because i have to work later. i just don't really want to spend $500 on a new one.
Old Jan 14, 2002 | 03:24 PM
Kevlo911's Avatar
Kevlo for President
if all else fails go to the junkyard... u can get one from a 95-99max and I30 all models
bout 50$+
Old Jan 14, 2002 | 06:02 PM
well guys i me and my gramps tore the sucker apart and soldered the prongs together and voilah! fixed, now my baby is purring again...
Old Jan 14, 2002 | 07:28 PM
RedMax95's Avatar
sweet, i love it when things work
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
cruce91
Sep 20, 2015 10:23 AM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
