Bearing On Other Side Of Input Shaft?
Old Jun 11, 2013 | 04:09 PM
Aflion's Avatar
Hey, can someone please tell me what the other bearing is on the input shaft in the RS5F50A 5 speed transmission is? I took my transmission apart and bought the input shaft bearing thinking that was it because the symptoms were the same and it's a common problem, but my input shaft bearing is fine. It's the bearing on the other end of the shaft, and I can't find it outside of a complete rebuild kit.
The part number on it is 28BC08S1, and it is a Nachi. Is there a specific name for this bearing? Can someone tell me where to find it, and from a reliable source?
It's number 126.
Thank you.
Old Jun 11, 2013 | 05:40 PM
Nealoc187's Avatar
SLOW
do you mean a place to find it like, besides the Nissan dealer?
141 is the input shaft front bearing and 126 is the input shaft rear bearing...
you could also get it from a bearing supplier, but that's more trouble than it's worth most likely. i priced every bearing in the transmission in the trans at a bearing supplier back years ago and the only that made sense to get anywhere other than the dealership was the input shaft front bearing from the RS5F50V (VLSD version of this trans).
Old Jun 11, 2013 | 06:28 PM
Aflion's Avatar
Yeah, i would buy the rebuild kit,but i cant afford it, as i had to also replace the clutch and pressure plate, and will have to replace valve covers, water pump, and brakes after the trans. I'm going to call a local bearing supplier tomorrow to see how much it is, but they do have it.
Thank you for your reply. But in your opinion, should I return the front input shaft bearing, or go ahead and replace it too? It doesnt grind or anything like the rear one does, but I honestly don't really want to have to go back into my transmission. But I'm also strapped for cash and could put the money somewhere else.
Posted from Maxima.org App for Android
Old Jun 11, 2013 | 06:41 PM
Nealoc187's Avatar
SLOW
you can buy the bearing individually from the dealer. you don't have to buy a kit (in fact i didn't know they had "kits" at the dealer, never heard one mentioned before and I've rebuilt a lot of these transmissions always using dealer parts except that VLSD front bearing as i mentioned before).
i would replace the front bearing. that bearing is the most susceptible to abnormal wear in the trans, if the rear bearing was worn out the front bearing was surely seeing loads it is not designed for, and is probably compromised.
Old Jun 11, 2013 | 07:14 PM
Aflion's Avatar
Alright, thank you. And I don't think they sell kits, but Ive never bought from a dealer before, so idk. Lol.
Old Jun 15, 2013 | 05:49 PM
hatchexhaust's Avatar
It's number 126.
Thank you.
So? Is your max lowered? If so its prob the drivers side axle clicking not the barrings? My max is lowered on s-techs by tein and it eats drivers side axles like candy...
Old Jun 15, 2013 | 05:51 PM
The inner cv just to much of an angle withe the s-techs; (
Old Jun 15, 2013 | 07:26 PM
Aflion's Avatar
Ummm, wrong thread. Lol.
Old Jun 15, 2013 | 09:04 PM
Nealoc187's Avatar
SLOW
lol
Old Jun 16, 2013 | 09:00 AM
Derpington's Avatar
Try gttransmissions.com, i got their rebuild kit for my 95 5speed (open diff) for around 230$ but maybe they can sell you just the input shaft rear bearing
Old Jun 16, 2013 | 03:43 PM
Aflion's Avatar
I had to buy a full bearing and seal kit. My other bearings were pretty shot as well, but gears and synchros were alright. (surprising since previous owner ran gl-5 in it, and was a few quarts of gear oil low when I drained it)
But i bought the bearing kit from American Powertrain Warehouse. All oem manufacturer bearings and seals for $123 shipped to my door.
Thanks for the suggestion on where to buy though.
Old Jun 16, 2013 | 04:05 PM
Derpington's Avatar
No problem, wish i would have found it for 123$ haha
The Frye
Sep 2, 2021 11:03 AM
londonflu
40
Sep 25, 2015 09:11 AM
conansriver
Sep 11, 2015 10:26 AM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
