should i tighten the thottle cable?
Old Jan 14, 2002 | 08:31 PM
ocm2001's Avatar
i was hearing that some people were tightening their thottel cable and they could feel a difference in the low end? is that true? if so how do you do it?
Old Jan 14, 2002 | 08:35 PM
Craig Mack's Avatar
All YOUR grammer belong to me
You won't actually improve your actual times with this, although you might feel more pull. Usually your throttle cable is fine, neither of the Maxima's in my family have ever had a loose feeling. Overtightening is also bad and will make your idle go crazy.
Old Jan 14, 2002 | 08:49 PM
Kashoggio's Avatar
i head if you cut it you wont go anywhere
Old Jan 14, 2002 | 09:33 PM
araffio's Avatar
Re: should i tighten the thottle cable?
I tightened my throttle cable slightly when I cleaned the throttle body a month or two ago under the impression that it would tighten my gas pedal and increase low end, I was dead wrong. When I started the car, the idle was up to 2500rpm and my gas pedal was just as loose. Unless your throttle cable is EXTREMELY loose, which it will not be, you should leave it be. Tightening it will not benefit you at all, unless of course its a wet noodle.
Old Jan 14, 2002 | 11:13 PM
95emeraldgxe's Avatar
you got it......if u cut it......you aint going anywhere =)
Old Jan 15, 2002 | 04:42 PM
bigballen's Avatar
there is a small plastic block uder the gas pedal, put there as a factory saftey procaution to keep you from actully going wot take it out and you shall feel like you have a little bit more extra throttle to play wit
Old Jan 15, 2002 | 05:03 PM
BTW - dont tighten it!!!
Old Jan 15, 2002 | 05:32 PM
maxedout95's Avatar
Did anybody ever tried that mod
Old Jan 15, 2002 | 07:47 PM
Toolrocks's Avatar
I certainly wouldn't cut the throttle cable but after I "properly" adjusted mine the throttle was definitely more responsive. The manuals all say to loosen the locking nut and turn the adjusting nut until the throttle drum just begins to move - then back the adjusting nut out a turn or two and then tighten the lock nut. Hope this helps.
Old Jan 15, 2002 | 09:02 PM
AznStevie's Avatar
Re: Re: should i tighten the thottle cable?
uh...my super afc tells me that i have 100% throttle hehe... so i guess that's good enough hehe...i can't floor my car right now..since my car would start to hop even i do it slowly
Old Jan 15, 2002 | 09:03 PM
NISMO808's Avatar
They recommend only tightening it if it's noticeably loose. If you tighten too much you have the potential of the cable stretching over a period of time and then u'll end up having to replace it.
Old Jan 15, 2002 | 09:32 PM
bigballen's Avatar
Re: Re: Re: should i tighten the thottle cable?
well i dont have all the great mods you have yet. im trying to get weapon-r to e-mail me back about the ecu and intake testing they are performing out here in california. they haven"t e-mailed me back as of yet, maybe they already found a test car. but in any case im going to try to get intake first , then exughst just haven"t made my mind up yet on which one. wished my wheels hopped when i hit the gas.
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
Noela
Sep 26, 2015 08:22 AM
thenewguyy
Sep 12, 2015 11:12 AM
pktaske
Sep 4, 2015 08:40 AM
