little thumps during stoplights
Old Nov 11, 2000 | 07:26 PM
Ch12i5
i experience a small jerk or thump in the engine while i'm waiting at a red light while in the regular "D" position. it could almost feel like the bass of a music beat...something of that sort, but it isn't...i know it's in the engine. are there any major problems? what can i do? it's really annoying to feel this on a maxima...thanks!
Old Nov 12, 2000 | 06:37 PM
ny96max's Avatar
HAD the same problem
i had the same problem for a while. It started when i changed my spark plugs. It ended up to be a bad Ignition Coil Pack. $70 at a local Nissan dealer. This is after i went to 4 mechamnics and 400+ dollars.
Old Nov 12, 2000 | 07:01 PM
Daniel B. Martin's Avatar
Re: HAD the same problem
This is interesting. Even if you know you have a bad coil, how do you figure out which one it is?
Old Nov 12, 2000 | 07:13 PM
ny96max's Avatar
Re: Re: HAD the same problem
well, when i originally pulled out the coils, one of the rubber boots at the end of the coil got stuck at the bottom around the spark plug. So i just started out with that one and luckily that was the one that did it. I mean you can buy one for the back of the engine (longer coil) and move it around, then buy a shorter one for the front half and play around with that. Hopefully you will get lucky like i did. Have you done the 60K tune-up yet??
Old Nov 13, 2000 | 04:50 AM
Re: Re: Re: HAD the same problem
... ... Hopefully you will get lucky like i did. Have you done the 60K tune-up yet??
No, my '99 GXE has only 19K miles and is running fine. My question about "how do you know which coil is bad" was for curiosity only.
Need help
23
Oct 2, 2015 08:56 AM
Shadow
Jul 11, 2001 12:21 PM
ToYLeT902
Jul 10, 2001 02:03 AM
The_quorum
Dec 13, 2000 10:39 PM
mingo
Sep 27, 2000 09:27 AM
