replacing front end of a 95
Old 08-19-2013 | 09:51 PM
WhyBeYou's Avatar
So I have a 95 maxima and I was involved in a wreck about a week ago. I am trying to find out if I get parts from the junk yard to replace some of the tore up ones if there is anything I have watch out for. Say I get some parts from a 98 or so. Or if they are all the same. I know there are some slight differences between them
Old 08-19-2013 | 09:53 PM
Fakie J Farkerton's Avatar
Only the SE has small differences.
Old 08-19-2013 | 10:27 PM
WhyBeYou's Avatar
Do you happen to know what any of them are because I basically have to replace every bolt on piece behind the bumper cover.
Old 08-19-2013 | 10:37 PM
Do you have an SE?
If not then just avoid SE's.
The only real difference is the FSB and some extra body support in the front end iirc.
Old 08-19-2013 | 11:09 PM
WhyBeYou's Avatar
Honestly I do not know. I known it has everything but the Bose and leather
Old 08-20-2013 | 12:42 AM
tosheto's Avatar
Fog lights - SE
No fog lights - non SE.
If you have 95, look for 95-96 Maxima in junk yards and pull off the front end and be done. There is a difference in the 97-99 front end compared to the 95-96.
Old 08-20-2013 | 01:13 AM
^^ your right.
I wasn't thinking about the bumper and grill appearance.
Old 08-20-2013 | 11:28 AM
maxfever1987's Avatar
Since you have a 95 and you find a 95-96 everything will be the same, now say u go there and you find a 97-99 here's wat will be diff.
The front bumper
Grille
Same style headlights but with a clear lens
Fog lights
Everything bolts right upto your 95, you don't need to do anything special in terms of installations,
Couple things to keep in mind, if you decide to take the 97-99 front bumper take the grille also and vice versa, or else you will be left with a gap if u put ur 95 grille on the 97-99 bumper,
If you take the 97-99 fog lamps make sure you also take the mounting brackets,
if you have more questions please ask
If you go to the junkyard and need immediate help I'm a phone call away 917-442-1775 call or text is fine,
Old 08-20-2013 | 01:34 PM
WhyBeYou's Avatar
Ok thank you. My car came with fog lights but I haven't had them in for awhile now. But I need everything bumper cover, bumper support headlights. The only thing that didn't get messed up where the marker lights.
Old 08-28-2013 | 06:53 PM
jfactor's Avatar
My swaps
I have successfully swapped a 99 se rear bumper cover, 97 se front bumper cover and passenger fender, 99 grill and 99 se fogs. All front end parts bolted right on up to all the 95 stuff, even the fogs. The rear cover on the other hand took some extra holes for the bolts to line up. On a Friday night with a twelve pack you can accomplish a lot.
Old 08-28-2013 | 07:19 PM
DennisMik's Avatar
Yeah, but how did it look Saturday morning?
Old 09-22-2013 | 02:43 AM
jfactor's Avatar
Looked awesome Saturday morning Dennis.
kingw323
20
10-21-2015 09:36 AM
homeyclaus
09-03-2015 07:15 PM
Balkins
08-12-2015 07:39 AM
Samedi
08-12-2015 02:54 AM
laparka66
08-06-2015 10:36 AM
Quick Reply: replacing front end of a 95
