need help with buzzing noise...
I am trying to start my recently converted ti 5 speed 4th gen. It tried to turn over a fee times but wouldnt start. Noe everytime I turn the key to the starting position I get I serious buzzing noose coming form the driver side kick panel. Itook the panel off and noitced that the buzz is coming from behind some kind of dynomat sound denting material. Would anyone happen to now what could be cause this sound., it would help like crazy...
There are 2 relays behind the insulation, the sunroof relay (optional) and the fuel pump relay. Also, the brake ABS controller is behind there if you have ABS.
There are 2 fuses associated with the fuel pump relay. Fuse # 17, 10 amp, is for the energizing coil of the relay. Fuse # 32, 15 amp, is for the power the relay sends to the fuel pump.
Fuse #17 is in the middle column of fuses, the 6th one from the bottom. Fuse # 32 in in the right most column, also the 6th from the bottom, right next to fuse # 17. When counting fuses, if there are any blank positions, count those empty spaces.
Dave B
Oct 20, 2001 10:32 AM
RACEFACE
Sep 11, 2001 04:37 PM
