radiator top mount
Old Dec 5, 2013 | 03:24 PM
edwardh1's Avatar
radiator top mount
about a year ago I had a new radiator put in.
the top mount on both sides seems loose- that is the pin sticking up from the radiator itself is small in the hole from the "mount" that lays over the top of the radiator. you can move the radiator maybe 3/16 of an inch. is this good or bad?
mechanic uses napa and their stuff is mostly chinese so maybe the rubber part is wrong size or the mechanic left out a piece, should I put a rubber piece like from a rubber hose around it? of leave it as it is?
cant post a pix tho I have one
Old Dec 5, 2013 | 03:30 PM
pmohr's Avatar
No more Maximas...
The radiator should be kept relatively right. The rubber inserts are only $2.74 @ Courtesy.
Even with the rubber inserts completely gone, I wouldn't expect any damage from the radiator being allowed to bounce around.
Old Dec 6, 2013 | 06:51 AM
Reality sucks's Avatar
exactly, i lost mine last replacement, found a new set at the jy for 1.00 easy fix.
Old Dec 6, 2013 | 11:02 PM
jfactor's Avatar
Wow! You were actually able to find rubbers in good condition at the junkyard? That was impossible when I needed to replace mine. I ended up scrounging up a couple of expandable freeze plugs laying around in the garage and using the rubber from those. Much better than oem rubbers.
Old Dec 6, 2013 | 11:26 PM
DennisMik's Avatar
Get the lower ones, too.
upper part # 21506-51E00
lower part # 21507-1E400 cars built 02/94 to 09/96
lower part # 21507-59Y00 cars built after 09/96
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
