98 SE wheels and tires
Old Jan 17, 2002 | 09:11 PM
Jim Sundin's Avatar
What are the alternate sizes of tires that fit on a stock 98 SE rim? Stock is 215-55-16 correct? Any other size and width that is recommended to be better than stock?
Old Jan 17, 2002 | 09:20 PM
JSMax's Avatar
Sold
Re: 98 SE wheels and tires
Jim, when I purchased new tires, I went a little wider, and a little shorter. 225-50-16. The wider footprint is nicer for added traction, and does not mess up handling or anything. No noise from the tire rubbing is evident and you have a much wider choice when you pick this tire size. Hope this helps you out...
Old Jan 17, 2002 | 09:42 PM
95emeraldgxe's Avatar
it depends.......is there any reason why u wanan change the size.....or u just wanna know for fun??
Old Jan 18, 2002 | 05:40 AM
iwannabmw's Avatar
It depends, if you drive really hard, like 9-10/10ths, don't go to the 225 on the 6.5" rim. They are too wide and will roll over on you in these conditions. This won't be an issue on the street, but on the track it will hurt you. If you're not going to go on the track, 225 look much better and you have more choices.
Old Jan 18, 2002 | 05:47 AM
AndyXXL's Avatar
I run 225/55-16" on SE wheels without any problems.
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
