Fuel Tank cracked question.
Old Jan 3, 2014 | 02:56 PM
Johnny9595's Avatar
Tank sprung a leak somehow and mechanic says I should replace the whole tank any alternatives to replacing the it? I need help! Kinda on a budget but the price of part and labor is high.
Old Jan 3, 2014 | 03:18 PM
DennisMik's Avatar
Sometimes you get stuck between a rock and a hard spot. And that is exactly where you are.
Patching a fuel tank is successful less than half the time. Part of the problem is what caused the tank to leak, part of the problem is where it is leaking, how big is the hole, etc. For a patch to work the best, it has to be on the inside so that the weight or pressure of the gas pushes on the patch. And that is pretty hard to do with a gas tank.
In most cases, removing the gas tank is needed in order to patch it.
Just bite the bullet and replace it.
Old Jan 3, 2014 | 09:00 PM
Johnny9595's Avatar
It's on the front side my mechanic said its where the weld for the 2 hoses get clamped down. Going to try and patch if I can get it in there with out dropping it before I go and replace it. Thanks for the info Dennis.
Old Jan 4, 2014 | 10:55 AM
CMax03's Avatar
Weld it!!!!!! BOOOOOOOOOOOOMMMMMMMMMMM!!!!!!!!!!!! Listen to your mechanic! Either pull a junkyard unit if they are still on the car! Or order a new one! Now this is when I would use AZ!
Old Jan 4, 2014 | 01:46 PM
clive's Avatar
100% chingon
You won't find any adhesive that will patch it. Speaking from experience.
Old Jan 5, 2014 | 11:28 AM
CMax03's Avatar
Buy a new one or head to a salvage yard....
http://www.rockauto.com/catalog/raframecatalog.php?ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=d2v2snlt7qcqhsakt5g0bbibi1
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
doctorpullit
Mar 29, 2016 11:08 AM
