sound under right wheel
Old Jun 30, 2014 | 10:14 PM
LuminousX's Avatar
For awhile now I've been having the bang sound under the passage side of my car, the LCA was replace before the sound started, I'm not really sure, I also replaced my inner and outter tie rod and It's still there, it happens when I turn the steering right, and then back left or the other way around, doesn't matter if the car if movie not, any idea what's my issue?
Old Jul 1, 2014 | 07:53 AM
metalgod3082's Avatar
Check your ball joint or possibly your axle. Those can cause that
Old Jul 1, 2014 | 01:20 PM
Patm-a32's Avatar
When i had a similar issue, i did the lca myself and didnt tighten the sway bar link enough so it was clunking and making all sorts of racket. Check tightening it, check the link itself, change if needed and check the sway bar bracket bushing
Old Jul 1, 2014 | 08:28 PM
Alaskus's Avatar
Could be the spring binding? Search how to check the strut bearing.
how about a video?
Old Jul 4, 2014 | 07:32 AM
CMax03's Avatar
More than likely it's a worn or loose swaybar link....
Old Jul 9, 2014 | 08:20 AM
LuminousX's Avatar
I also believe it's the swaybar link so I ordered a pair, hope I'm right
Old Jul 14, 2014 | 05:47 AM
LuminousX's Avatar
well, I replace 3 parts so for, and this damn noise is still a pain in the ***, but I did nothing that it happens when the car is in drive then I put it in reverse then I would hear it, then when I go back to drive, I would hear it, do it sounds like something keeps slipping back, and forth, but I can't tell what part it is... any ideas?, Thanks
Edit: My control arms are less then a year old, I just changed the inner, and outter tie rod, and I changed the swaybar link, and the problems is still there
londonflu
40
Sep 25, 2015 09:11 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
