How do I support engine when removing timing chain?
Old 07-12-2014, 05:52 PM
mikeyen's Avatar
I'm down the point where I'm taking off the front cover, and it occurred to me that the upper pan has to be off, which means the motor mounts will be off.
Just a basic question, then: How do I support the engine with the center and right motor mounts out?
Engine sling?
mikeyen is offline
Old 07-12-2014, 06:01 PM
Fakie J Farkerton's Avatar
Cherry picker/hoist is best.
Fakie J Farkerton is offline
Old 07-12-2014, 06:47 PM
chrome91's Avatar
engine brace like so, sits on your fender sills and you hook it up with a chain or whatever to somewhere solid on the engine
chrome91 is offline
Old 07-12-2014, 07:52 PM
^ Holy crap that's way better than a couple 2x4s and some chain.
Old 07-12-2014, 08:03 PM
Maximeltman's Avatar
they usin somethin like that on the cover of haynes
Maximeltman is offline
Old 07-12-2014, 09:41 PM
Alaskus's Avatar
http://www.harborfreight.com/1000-lb...bar-96524.html
$20 less than a full crane (with coupon)
http://www.harborfreight.com/1-ton-c...ane-69512.html
Alaskus is offline
Old 07-12-2014, 11:32 PM
chrome91's Avatar
we use them all the time at work, those braces are a godsend to angle the engine re-installing a transverse transmission
chrome91 is offline
Old 07-13-2014, 01:43 PM
Quickywd01's Avatar
Right! I used 2x4's and rope when I didn't have my engine hoist. Tools make life easier.
Quickywd01 is offline
Old 07-14-2014, 09:41 AM
CMax03's Avatar
The upper Oil opan doesn't need to be removed! The lower needs to be removed too access 4 bolts that run through the upper oil pan!
CMax03 is offline
Old 07-16-2014, 04:40 AM
Chad_m's Avatar
Engine sling?
Of course what everyone posted is best, but if you don't know how to support the engine, I'm not sure you should be trying to fiddle with the timing chain.
If you don't have the money for the the sling, a jack stand under the actual compressor does wonders. That's actually how the FSM recommends doing it, other than the ac compressor part. I just find that spot safe and easy.
Chad_m is offline
Old 07-18-2014, 04:10 PM
Trini Boom's Avatar
+1. NO need to remove upper oil pan which means the crossmember will provide adequate support.
Trini Boom is offline
CorollaULEV
30
08-09-2021 08:11 PM
CRizz
41
06-07-2021 05:42 AM
maxinout93
10-27-2015 01:29 PM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: How do I support engine when removing timing chain?
