Need help! Please! 95 nissan maxima
Old Sep 28, 2014 | 04:45 AM
Paxiquao's Avatar
95 Nissan Maxima, I was changing out my car spark plugs all 6 and I notice when I got to the rear 3 spark plugs there was oil on them... so I brought the rear valve gasket cleaned out the spark plug holes and cleaned the sludge off of everything and hook everything back together... and when I cranked my car I and push down the gas pedal I heard a loud pop noise... so I turn it back off and tried to crank it again... it turned on but when I go to push the gas pedal the car shuts off completely! did I not hook up something right???
Old Sep 28, 2014 | 06:19 AM
Paxiquao's Avatar
Okay I found a small hose loose!
http://www.youtube.com/watch?v=lqJkGOlTvSo
go to 13:23 that hose at the top where do it connect!
Old Sep 28, 2014 | 06:26 AM
CS_AR's Avatar
Welcome to Maxima.org
Let us go through the steps taken to fix the oil leak for the other members.
1) An oil leak was found in the rear three spark plug wells.
Note: This can be from a leaking spark plug well seal that is mounted to the rear valve cover.
2) A gasket kit was bought that contains valve covers and spark plug well (hole) seals
Question_1: Was the Upper Intake Manifold (UIM) removed to replace the rear gasket and spark plug well grommets?
Questions_2: Can you provide a picture of the areas (parts, connections, and hoses) that were hooked up after the gasket and seals were replaced?
Ok - I think we posted about the same time..
Old Sep 28, 2014 | 06:37 AM
CS_AR's Avatar
The hose being removed at 13:23 allows coolant to flow through the throttle body to the EGR. I have 99 models with the electric EGR valve instead of a vacuum controlled EGR on the 95 model. So my EGR will look different.
Here's a picture of the coolant hose running from the throttle body to the EGR.
Does this help?
Old Sep 28, 2014 | 06:43 AM
CS_AR's Avatar
Did you see this guy's video? He shows the coolant supply hoses.
http://www.youtube.com/watch?v=C_2GsFzAaMc
Note: I've seen cases over the years where a coolant hose was hooked up to a vacuum hose by mistake. When the car starts it will pull coolant into the intake manifold. Double check the vacuum lines are only connected to other vacuum lines.
Old Sep 28, 2014 | 07:59 AM
Paxiquao's Avatar
New Shoes
Thanks You! you hit it right on the head! I'll let you guys know how everything went!
Old Sep 28, 2014 | 09:36 AM
Paxiquao's Avatar
What Is wrong?
http://www.youtube.com/watch?v=OZcnl...wtyclesVK_2CTQ
Now that I have everything hooked up its making this weird popping noise... watch the video and listen to the noise it makes...
Old Sep 28, 2014 | 12:46 PM
CS_AR's Avatar
Is there any chance that a screw or a small part may have fallen one of the intake manifold openings or into one of the spark plug holes?
Can you get a mechanics stethoscope or use a tube to listen to find the area where the noise is coming from?
I would try to run it as little as possible until you isolate and locate the noise.
Old Sep 28, 2014 | 12:57 PM
Paxiquao's Avatar
Yeah, I'm going to take everything back apart when I get off work to try to find out whats going on with it..
Old Sep 28, 2014 | 01:18 PM
Paxiquao's Avatar
Maybe I put those gasket in the wrong way, the ones that go over the spark plugs hoes? Idk...
Old Sep 28, 2014 | 02:50 PM
Paxiquao's Avatar
Its a BLOWN SPARK PLUG AND MAYBE A BROKEN IGNITION COIL... that makes that noise.... smh... hopefully I do NOT Have to rethreading tool! -_-
Old Sep 28, 2014 | 04:38 PM
CS_AR's Avatar
Could some coolant have been picked up by vacuum into the intake when there was a hose connection problem earlier and you noticed a loud bang?
If coolant got into a cylinder on a compression stroke -- the way my luck runs I would be looking a hole that would been blown through the side of the block or the top of the piston...
Old Sep 28, 2014 | 05:59 PM
CMax03's Avatar
EGR valve leak!
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
