hard start issues
Old Dec 23, 2014 | 05:01 PM
maximanate's Avatar
hard start issues
Please help I have a 99 maxima did a trans swap back in October and have had no issues tell last night my car would only crank tell I tapped the gas the pedal then it would start tonight I go to start car and nothing it just cranks I've thing I've read has taken me everywhere from starter to ground to cps sensor I want to know if im missing something thanks in advance
Old Dec 23, 2014 | 05:28 PM
Any codes?
Since you recently did a trans swap, you may have a grounding issue. I'd add two new grounds from the trans bell housing to the battery to see if that does the trick.
Are you sure you're not immobilized? What's the security light doing as you crank it?
Old Dec 23, 2014 | 08:28 PM
ac max 92's Avatar
If the last time you started it and had to tap the gas and now cranks but no start sounds like possibly your fuel pump may be done. Try turning the key to acc and listen to see if you hear the fuel pump prime and ofcoarse check for codes.
Old Dec 23, 2014 | 09:17 PM
96maxed's Avatar
I just had a similar problem, I had give it gas for it to stay on. Feels like it's getting no fuel to start up, idk. Ima do a tune up soon
Old Dec 23, 2014 | 09:35 PM
JoshG's Avatar
potentially ur fuel pump almost on its way out, i mean it makes sense if you have to give it gas to start it.. so its something fuel related. or possibly a grounding issue.
02PearlSE
Oct 7, 2015 02:12 AM
official_style
Aug 29, 2015 10:10 AM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
