Anyone have second gear slam into gear on your maxima?
Old Jan 29, 2015 | 05:02 AM
JLA117's Avatar
It only slams if you simply accelerate in first gear and let go of the gas pedal fast. At higher speeds from 20-40 on first gear it slams into gear shift if you let go of the gas pedal completely.
Old Jan 29, 2015 | 06:56 AM
njmaxseltd's Avatar
Check your motor mounts. Check the value of the drop resistor.
When the transmission is cold, it does shift a little harsh into 2nd under light to normal acceleration for the first few miles. Amsoil tranny fluid helped smooth that out for me.
Old Jan 29, 2015 | 07:23 AM
asand1's Avatar
The problem is a loose nut behind the wheel.
Old Jan 29, 2015 | 07:53 AM
Quickywd01's Avatar
Trans fluid pressure. It thinks you're going to shift under power. Get a valve body upgrade, synthetic fluid and fuild cooler. Perhaps you need a stickshift?
Old Jan 29, 2015 | 09:17 AM
njmaxseltd's Avatar
Old Feb 5, 2015 | 04:25 PM
JLA117's Avatar
Yes I do need the mount in bottom middle of engine. Could that be the cause?
Lakersallday24
Nov 7, 2024 07:31 PM
dank4us
34
Jun 10, 2024 03:45 AM
Quickgtp
Apr 13, 2017 03:30 PM
Hawkeye61
Aug 12, 2015 06:45 PM
MikesChevelle
Aug 10, 2015 10:53 AM
