Axle question
Old Mar 19, 2015 | 11:55 AM
Roachjuice's Avatar
Axle question
I'm in need of a new axle for the passenger side of my 96 se 5 speed. Does it matter if it's LSD trans or not? I honestly don't know how to tell if it is or isn't. No I'm not going out to a parking lot and doing a massive burnout to find out lol.
Thanks in advance.
Old Mar 19, 2015 | 01:02 PM
Roachjuice's Avatar
Originally Posted by Cylent_JDM
Look at the vin, if it has a V it has viscus differential (LSD) if it doesnt its non lsd.. Also the axles do matter...
Should have done a burn out lol
Sweet thanks. Looks like I don't have a V lol.
Maybe when I fix the axle lol. 👍
Old Mar 19, 2015 | 01:57 PM
95naSTA's Avatar
Only the driver's side is different.
Old Mar 19, 2015 | 02:59 PM
DennisMik's Avatar
The VIN does not contain any reference to the transmission.
The thing about the letter V is in regards to the transmission model number that is stamped on the transmission somewhere. But I don't know where that is.
model number RS5F50A does not have LSD
model number RS5F50V does have LSD
Unless the car is originally from up north by the Canadian border, it is highly unlike to have LSD.
One way to tell is to jack one of the front wheels up off the ground. With the transmission in neutral, turn the wheel by hand. If the wheel turns, you do not have LSD. If the wheel does not turn, you have LSD.
But as 95naSTA said, the passenger side axle is the same for both types of transmissions.
Old Mar 19, 2015 | 04:42 PM
asand1's Avatar
The VIN plate on the firewall includes the Transmission code.
RS5F5OA=5MT open
RE4FO4A=AT open
RS5F5OV=5MT VLSD
RE4FO4V=AT VLSD
Passenger side axle is same between ALL transaxles, and drivers side is different between all i believe.
Old Mar 19, 2015 | 06:12 PM
JEB Davis's Avatar
Not trying to hijack the thread Roachjuice, just avoid starting a new one for a quickie for the same part. I have a 98SE 5MT open ( RS5F5OA ). Will a passenger-side axle from any year 1995-99 fit?
Old Mar 19, 2015 | 10:19 PM
asand1's Avatar
It should. Plug your info into Rockauto and pull up a shaft. Click on the blue highlighted part number and it will show you all the applications it fits.
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
