Hesitating to accelerate
Old Apr 20, 2015 | 06:40 PM
datboimell's Avatar
Like the title says my maxima is hesitating to accelerate and j don't know what it could be. There's no misfiring or anything all my coils are cool. The exhaust has no holes or anything. Idk what the damn problem is. Please people help. This issue has my check engine light on and I can't pass inspection!
Old Apr 20, 2015 | 07:08 PM
Mateen995's Avatar
Maf
Old Apr 20, 2015 | 07:09 PM
JoshG's Avatar
Mass air flow sensor bud, does it pass over 2.5k RPM? need more info what your problem is
Old Apr 20, 2015 | 07:25 PM
datboimell's Avatar
It will go well over 2.5k but when driving it's like it will hesitate while I'm gassing like its holding back then it will let go and take off. I remember when I got the codes checked one of them was the AITS but my max didn't have one because the previous owner cut it off for whatever reason so I fixed in a used one from the junk yard and that's good now! I'm going to get it checked again tomorrow to see what codes are still there.
Old Apr 21, 2015 | 04:36 AM
Turbobink's Avatar
If the CEL is on then there's a code stored ... what's the code(s)?
Old Apr 21, 2015 | 04:39 AM
njmaxseltd's Avatar
Is the car up to date on maintenance? Spark plugs, fuel & air filters?
Old Apr 21, 2015 | 09:59 AM
datboimell's Avatar
Yes just gave the car a nice tune up. Oil change, oil filter, air filter, antifreeze was flushed, spark plugs. I'm going to try and make it to get the code checked again. I wrote it down before but lost the paper
Old Apr 21, 2015 | 10:26 AM
datboimell's Avatar
I just noticed while driving that the car struggles to go over 2.5k then sometimes it will jump to 3k and make down to 2.5k
Old Apr 21, 2015 | 01:11 PM
cashoit's Avatar
Sounds like the MAF is on its way out. Try to clean the MAF with MAF cleaner. Check for any vacuum leaks too
Old Apr 22, 2015 | 03:11 AM
bumpypickle's Avatar
try maf cleaner. If it does not help, Purchase a used maf at a junkyard and install after cleaning with maf cleaner. Do not replace anything until you see the codes, although this does sound like your maf. You can check the codes yourself. There is a guide in the stickies. READ IT, it is very easy.
Old Apr 22, 2015 | 11:18 AM
datboimell's Avatar
Ok I used my head and did some reading in the stickies and all that jazz and I just came from getting my light checked.
Now over the weekend when I checked it only should 3 codes but today looking back the scanner he used looked out of date and old.
They used a newer one today.
I now have 5 codes and this is what they are!
P0443
P1441
P0141
P0110
P0306
The last one for sure is cylinder #6 misfiring! So I'm going to jump on that ASAP!
But as for the others were do I start!?
Old Apr 29, 2015 | 08:35 AM
TSoprano's Avatar
If your MAF is on it's way out here's how to check it..
https://www.youtube.com/watch?v=ewjO9JVr8NU#t=62
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
jchronis2552
Sep 21, 2015 05:52 AM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
