2000 rear struts in 1999 maxima?
Old Dec 5, 2015 | 06:59 AM
Chefmatt's Avatar
Opinions on installing a set of rear struts for a 2000 maxima in a 1999? Bolts do not line up but everything else is same. Would be a matter of drilling two matching holes about 1/2" outside stock holes. What do you guys think? See pic
Old Dec 5, 2015 | 12:29 PM
jerrod99_se-l's Avatar
If everything is the same as you say it is..why drill holes that would weaken the metal in the mounting location? Why not just swap out the strut mounts? No drilling required..
Old Dec 5, 2015 | 11:03 PM
Finkle's Avatar
I don't think the two holes will make a difference. Go for it if you want to, but good luck getting it perfectly centered.
Why don't you swap the mounts? Are the springs the same?
Old Dec 6, 2015 | 05:30 AM
I know the rear struts are not the same...two different part numbers...not sure about the springs
lustrouse
Feb 1, 2016 09:10 PM
dsonnylal
Oct 27, 2015 03:33 AM
Tyler Daniel Jordan
Oct 20, 2015 09:17 AM
brianoats
Oct 10, 2015 01:21 PM
jerrod99_se-l
Oct 5, 2015 01:04 PM
