URGENT!!!! Clicking when starting.... runs fine after jump
Old Dec 22, 2015 | 09:27 AM
maxima209's Avatar
Ok guys got a problem with the max. When I go to start it up all I get is a clicking noise but if do it for a while it will eventually start up. Or if I get it jumped it will start right up too.... and once started it runs great no light no problems. Turn the car off and go to turn it back on jus clicing again... idk if it's a battery issue or what any help would be great
Old Dec 22, 2015 | 11:53 AM
Most likely, starter (solenoid) is on it's way out. Replace the starter.
But first, check your battery voltage prior to start up, and observe battery voltage during startup. If battery voltage gets too low (and hence not enough juice going to starter), car won't start either.
Old Dec 22, 2015 | 12:57 PM
theWalkinator's Avatar
Always check battery first. If on own battery it just clicks but starts right up if jumped, then it is pretty sure your battery does not have enough juicy to energize starter solenoid, so either get battery fully charged or take the battery out to autozone to have them tested. Also, if you have multimeter, measure the voltage first, after start, measure the voltage again, it should read some where between 14.2 and 14.8 volt if alternator is working.
Old Dec 22, 2015 | 06:17 PM
asand1's Avatar
Low battery, bad connections, bad starter (solenoid), in that order. If it was a bad starter or connections it would still click with a jump on it.
Old Dec 22, 2015 | 06:21 PM
Not necessarily....
Old Dec 22, 2015 | 06:34 PM
asand1's Avatar
Not necessarily....
There are two kinds of clicking. A continuous fast clicking and a single click. Continuous fast clicking is generally caused by low voltage not being able to keep the hold-in windings of the starter solenoid energized. Solenoid then returns to rest where the pull-in windings are again energized and the cycle repeats itself. With this type of failure it can be a low battery, bad connections, or a bad solenoid. In this scenario if it were the cables or solenoid then jumping would have no effect, as the voltage drop is between the battery and the starter.
Bottom line is, get a voltmeter and check battery and voltage drop on cables. Or start buying parts until its better.
Old Dec 22, 2015 | 08:03 PM
Half Assed's Avatar
You need to exchange aproximately $125 U.S. dollars for a new car battery at your local auto parts retailer. Spend more currency to achieve a better warranty.
Old Dec 22, 2015 | 09:59 PM
surban1's Avatar
great explanation of the repeated/fast clicking.
how about if it's just the single click; what's that indicate???
Old Dec 22, 2015 | 11:46 PM
bumpypickle's Avatar
your probably overthinking the problem like i did...heres my thread from a year ago: https://maxima.org/forums/4th-genera...s-problem.html
Old Dec 23, 2015 | 04:30 AM
Turbobink's Avatar
Check the battery voltage with key off. If good;
Check the battery voltage with engine on. If good;
Check the battery voltage with engine on and all accessories + headlights on. If good;
Check voltage at the starter with key off.
Having completed these simple tests, you'll have found your issue.
JoshG
24
Dec 10, 2015 10:24 AM
hithesh
Oct 27, 2015 10:15 PM
rkspec
Oct 27, 2015 09:42 AM
Tgodwin3480
Oct 15, 2015 01:35 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
